so when I look for one, I just need to specify "PhD M6 Black Edition Standard Values," right?
The standard values were:
Level 1 = 5.0 volts
Level 2 = 6.8 volts
Level 3 = 7.5 volts
Level 4 = 10.8 volts
The MN61 (my favorite on the PhD-M6) at anywhere between 9.0 - 9.2 volts would be awesome.
So if you are looking for an used pack, you need to find out what 4x voltages that used pack was programmed to (the original owner will know), and based on those 4x voltage settings, the bulb chart http://m3coupe.com/electronics/PhD/part2/PhDM6_Bulb_Chart_8_21_10.png, will guide you as to what bulbs work best at each of those 4x voltages.
I would say that most of the packs had some custom values (meaning not the standard 4x), but it you can find out what Cx values were used, the Sales thread should give you enough indication of how that particular pack was programmed.
As always, if in doubt, come back with questions 🙂
Will
