ZuluWhiskeyFox
I recently bought this light on the BST. I knew at the time is was not working I thought it would be neat to get it working again. I believe it is one of the older ones that is capable of running either Li-Ion, alk's, or NiMH. Most of the Fenix line up can't use Li-Ion, to bad.
So I get the thing apart to find that there is one component that appears to be toast. Not exactly sure what it is but appears to be a regulator of some sort. It's the black chip like thing with 6 legs (just below the inductor). One of the legs in the middle of the top side is larger than the rest. There are no markings of any kind on it. It appears as though whatever markings there once were are burnt off. The surface is sort of dull and has that burnt look about it. The red wire is long enough to reach across the two lower right legs. However, it may have become seperated from the center leg when I was picking off the white silicone like stuff that was covering the connections of the two wires.
So what I guess I'm hoping for is some help in identifying that one component, and detirmining whether or not the red wire is supposed to be attacthed to the center leg of that chip. I guess while I'm in here messing about I might try and increase this circuits output a little. And of course you just know that I'll be putting a SSC-P4 in there as well.
Any light that can be shed on this matter would be greatly appreciated.
cheers,
zwf
cheers,
zwf
