Hi,
It's my first post here!
I initially started this thread to compare the Fenix HT18 and the Acebeam T28, but I've since managed to answer most of the questions that I had about the Fenix, except for one, and also decided against the T28, so I've decided to edit my original post to reflect this, and added the info that I found out, in case it helps anyone. Also, if anyone can answer my final question (bottom of this post), it would be much appreciated.
Questions with answers...
- Is there sufficient clearance in the battery tube for 21700 cells with an external diameter of 21.8mm? I believe the included cell is only 21.5mm - ANSWER: yes, apparently the internal diameter is 22.05mm.
Questions with some info...
- Does the USB-C port on the included battery support charging using a USB-C>USB-C cable, as opposed to the included USB-A>USB-C? INFO: I haven't, as yet, been able to answer this for certain. However, I believe I am right in saying that the Fenix PD36R is one of the only lights that can be charged using a USB-C to C cable, so it seems fairly likely that, as another Fenix product, this battery may also be able to be charged in such a way, but I can't say for certain. I will update here if I find out for sure.
:shrug:Remaining Question...
- Apparently the light runs at a lower turbo output when using 18650s. How does the light know what battery is inserted (is it just via voltage sag on the smaller cell)? Basically what I'm trying to find out is if I'll have any problems reaching the full turbo output using (good quality) non-Fenix branded protected 21700s.
Thanks!
Alex.
Thanks!
Alex.
