CaNo
lovecpf,Nitecore is the best!
Ima put this quote to the test!
Its official... my Nitecore and clip is coming in the mail today! WOO HOO!!! i just didnt buy any flashlight lube... hope i wont need it for a while! lol 😗
Help Support Candle Power Flashlight Forum
hmmm... will it work with the Q5 head? And how much more significant is the throw compared to the L1D? Do you think the P2D will be able to handle 3.7 rechargable cr123's? It uses the smooth reflector correct? Correct me if im wrong...
Ok I love both of these lights, but truthfully I am quite disappointed. Disappointed in the throw. I ordered these lights without putting this in consideration.
You'd be using the head you own....
The L1D, L2D, and P2D heads are identical.
That head is not designed for Li-Ion cells. It will work, but only in direct drive, and you'll loose the low modes.
Be disappointed in your selection process, not in the lights. As my dad used to tell me... "act in haste and you will repent in leisure". The D10 on 14500 does quite a respectable job in throwing, given the size of the light, though that is not what it is optimized for nor does it compete with lights designed to be "throwers".
But going back to the topic, someone suggested to get the p2d body.... how much more throw will this p2d give me compared to the one the L1D Q5 already gives? I assume the p2d uses a smooth reflector?
Did you read above? You would use the SAME HEAD YOU HAVE NOW.
As or the nitecore D10... i guess i will have to suck it up with the OP reflector or risk voiding the warranty and find an aftermarket smooth reflector i take it? :shakehead
Actually it is not above... but if i click over to page 2... i can find the post
Pardon my blond moment as i do not own a P2d head. :wave:
"Suck it up"? If it's that much of a problem for meeting your primary need of throwing, just sell it to someone who appreciates it for what it is. The D-10 reflector gives you a gorgeous general use beam... I wouldn't want to trade it for anything else, myself. Going for a small, tight hot spot wouldn't do anything for you in general use. If I want to light up stuff in the far far distance, I just use a light suited to that. For everything else, I think the D10 and its native reflector are just right!
Check post 88.
And yes, you do own a P2D head. You own the L1D, right? Same head...
Your slick! you managed to catch the quote a few seconds before i changed it to page "3" haha you got me there :naughty:
And no i do not own a P2D head. I own a L2D Q5 head ty very much! :twothumbs
There is absolutely NO difference.
