Fenix L1T V2.0
harddrive
Australia
I was just about to order a Fenix L1T V2.0 RB80 from the fenix store:
https://www.fenix-store.com/product_info.php?cPath=22_76&products_id=334
But now I'm having second thoughts after these comments by BHDS:
The L1T aint that great either:thumbsdow I have one and compared it side by side with my L1P and after about 15-20 minutes the two are pretty close to equal in brightness. At about 50-55 minutes its dying. 65 minutes and its dimmer than a first edition arc aaa. (standard version)
The low is too low for anything useful. The high is only useful for about 20 minutes.:shrug:
What do other L1T owners think? Are they that bad?
P.S. No disrespect intended towards BHDS, just looking to see if others have had the same bad experience.
Re: Is Fenix L1T V2.0 really that bad?
I had an L2T V2 with aL1D body and it lasts hours on a Lithium Primary.
I runt this light with a P2D body (1 x cr123) and I think it works fine, its my EDC and have been for a while!
I havent tried to measure the runtime on it, but I think that its not very long on high, I usually use it on low, works fine most of the time!
I really like the beam, its not any ugly rings like cree leds have!
The beam are a bit greener but its warmer than my crees.
I think this review should answer any questions about how the L1Tv2 and L2Tv2 perform.
http://www.candlepowerforums.com/vb/showthread.php?t=175758
These lights are really about the interface which is similar to the T1 with the original forward clicky switch and simple 2 level design.
Most of the high powered lights today need a lot of battery power. Alkalines will not supply that power. You need 'DIGITAL' batteries. Take a look at Chevrofreak's runtime graph of the L2T: (sorry he did not do one for the L1T but it is the same head)
http://www.candlepowerforums.com/vb/showthread.php?t=177886
Notice how short the alkaline runtime is on alkalines. 32 minutes on 2 batteries. (The L1T/L2T head uses 2/3 the power to produce 2/3 the light on a single AA so bhds runtime of 20 minutes is accurate FOR ALKALINES ONLY).
Switching to 'Digital' batteries tell a different story:
1 hour 46 minutes on NiMH.
2 hours 7 minutes for Energizer e2 L91 lithiums.
The L1P does have better runtime but is 1/2 as bright.
2 hour 35 minutes on NiMH.
3 hours 10 minutes on lithiums.
http://www.candlepowerforums.com/vb/showthread.php?t=103499
Don't let bdhs using the incorrect battery for this light scare you off. I you will not use your light much buy a pack of Energizer L91s. If you will use the light a lot get some Eneloops or other LSD NiMH batteries and a charger. Make sure the charger will charge single cells!
As to brightness the L1T low mode is less than the L1P single mode but is perfectly adequate for indoor use. And the high mode is twice as bright as the L1P.
I am quite happy with my L1T. Hardly uses my L1P anymore.
Now to find the other thread to let bdhs know he is using the wrong batteries.
The L1T v2.0 is not a light for alkalines. Lithium primary and NiMH only will let the true power "shine"....
I love my L1Tv2.0, no complaints at all. I run lithium primaries and find both output levels quite useful, runtime is great.
I have a L1T V2.0 and have been using it as my main go-to EDC since November. The interface is wonderful, and it works like a charm on Sanyo Eneloops. There are only two minor points that could be refined
1. Switch is a little noisy (electronically). You can cause the light to flicker pretty badly if you hold the switch at a certain point. A self-cleaning Mag switch would be better.
2. When you turn on the light in 'low', there is a very quick bright flash.
Other than that, it is perfect at what it does. I carry a Lummi Raw Ti at all times, but the belt holster and user interface of the L1T V2.0 means that it actually sees more use.
at first I had some trouble with my switch to, it would flicker and sometimes not come on. I took the whole clicky apart and cleaned it. Now it works very nice! Not a problem since!
I'll second what FlashSpyJ said about the switch,after taking mine apart and reversing the washer thats in there,it positioned the switch closer to the outer boot(mine was warped from the way it was stamped)and cleaned up a lot of the slack.I have brighter lights,but I find I carry this light most often.There are better EDC's,but not at around $40.00.I run mine on Eneloops,and have no complaints with the runtimes.I have the L1T v2.0,with the forward clicky.
Michael
You can't run high output modes on any of these latest generation LED lights and expect long runtime on alkaline.
The L1T v2 is an amazing light. 2:47 with a single 2650mAh nimh on high mode (source).
I like the forward-clicky on the v2 I got too. Much nicer than my NiteCore one. L1T v2 clicky > Romisen RC-G2 clicky > NiteCore clicky module
The RB80 I received has a really, really warm tint as well. It's a lottery with that though, unfortunately.
I don't know how many times I've seen threads with people disappointed with either output or runtime or both, simply because they were using alkaline :thumbsdow or carbon zinc :sick2: batteries. It takes an flashlight 101 education before people find out that it isn't the light that sucks, it's the gas they are feeding it.
The Fenix L1T V2.0 is a great light. Low is good enough for any job indoor and also perfect for going to the kitchen or bathroom in the middle of the night. The High out put is very up to par with my dad's Fenix P1 CE (90 lumens) except the P1CE have a bigger hot spot.
I highly recommend this light. It replaces many lights. Oh... I am using eneloop AA in the L1T.
Another nice thing about the L1Tv2 is that although the run time is poor on High with alkaline batteries, the Low runtime is still about 10 hours on an alkaline with very flat regulation. If you find yourself in an emergency with only alkaline batteries available, you can use them efficiently on the Low setting. Although the Low Level Freaks think the Low on the L1Tv2 is way too bright, it's actually a very useful level in an emergency. Handy attributes in an EDC.
Thank you all for your coments. I have just ordered one.
I will use it with some NiMH AAs I have here and maybe try it on Lithium AAs too.
If I like it and find it is getting a fair bit of use I might pony up for some eneloops and a beter charger.
On that note what charger would you recommend? Should I lash out on the Powerex MH-C9000 or is there a decent alternative for less cash?
The Maha (Powerex) MH-C9000 is a great charger. You could also go for one of these for less $$ and they are still very capable machines:
http://thomasdistributing.com/shop/...ml?SP_id=74&osCsid=f8k5tofm2insndb4q7kgpl4u57
http://thomasdistributing.com/shop/...ml?SP_id=41&osCsid=f8k5tofm2insndb4q7kgpl4u57
Sanyo Eneloops are a great bet for Nimh cells - that website has package deals including Eneloops here:
http://thomasdistributing.com/shop/...html?SP_id=&osCsid=f8k5tofm2insndb4q7kgpl4u57
http://thomasdistributing.com/shop/...ml?SP_id=67&osCsid=f8k5tofm2insndb4q7kgpl4u57
Definitely grab some Energizer L91 lithiums - at least to have on hand for emergencies. Their shelf life is, like CR123s, around 10 years (very very low self discharge), and they last a LONG time.
I have an L2T v2.0 and love it.
Have fun!:thumbsup:
L91's shelf life is actually quite a bit longer than CR123's, at 15-20 years to 80% vs. 10 with CR123's
I am just using a regular charger that comes with Eneloops, and it works fine. Maybe I am misssing 10% of runtime, and maybe my batteries will have a lifespan of 100 cycles instead of 500, but I don't think I'll ever get to that point, and if I do, I will have made extensive use of a the batteries, and will gladly purchase new ones.
