I am considering a Fenix L2D-CE. I have a review and it looks pretty good. Can anyone suggest a retailer that has this in stock? It looks like they are about the same price everywhere, but I just want to select a good reliable retailer.
Still my favorite flashlight, hands down, but I got one for an usher who couldn't use it because of the flash. But I didn't mind, that meant I had another one for myself!
Hi Jas,
Do be aware that your L2D-CE will probably have a little "bug", where when you either switch to 'low' or when you push the tailcap switch with the bezel loosened so it comes on in 'low', it will flash very brightly, briefly, before it goes into 'low'.
Kinda pissed me off when i got mine, because none of the reviews mentioned it, but when I brought it up here online, everybody said their's did it, and that was 'just how it was'.
- Thomas
>Rotating the head out of turbo mode apparently isn't enough to make it impervious to this odd drop-down-when-squeezed thing unless you back away from turbo even more.
As you said, you weren't unscrewing the head far enough. Unless it is backed off a 1/3 of a turn or more there's enough play in the threads for the head to make momentary "turbo" contact when pulled rearward or pressed sideways. Then when released the light returns to low mode, as it should.
