fenix LD10 replacement recommendations?
luke_DF
London, UK
My fenix LD10 R5 switch is dying on me. Perhaps not surprisingly I'm having hard time finding a replacement part for what I think is a light from 2011, so - in case the plan to bring it back to fully operational status fails miserably - I am on the lookout for a new 1 AA light.
Needs to have:
- back switch / no twist on-off
- mode switch via back switch or front element twist / definitely no side mode switch
- decent runtime, but not a priority
- good build quality
- close to LD10 beam profile would be great
Do you have any recommendations???
(I thought the Nitecore MT1A looked like a pretty close replacement, but that's also an R5 emitter, so I'm guessing a pretty old light - nothing wrong with R5 as far as I could tell, but I'm guessing maybe the world has moved on to some newer and better tech...?)
____This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____Up to $100.
3) Format:
____I want a flashlight (hand held/self contained).
4) Size:
____SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
____I don't know.
15) Water resistance
____IPX7 (Waterproof to 1 meter/30min)
16) Storage conditions
____In house (temperature/climate controlled environment)
How about the jaxman e3? It's a 1aa with a forward tail clicky. Nichia 219 (go with 4000k the 5700k seems low cri to my eyes). Runs 14500 if you want.
Promising! Form factor looks good - reminds me of a 1xAA Quark I had before I had the LD10. I'll look at some reviews. Thanks.
