Fenix funs check this new Fenix LD15 :
• Cree XP-G LED (R4) with lifespan of 50,000 hours
• Two modes of output:High (117 lumens, 1.5hrs) ->Low (8 lumens, 39hrs)
(Tested with Ni-mh battery with actual capacity 2500mAh)
• Stable current regulated circuit, stable brightness
• Uses one 1.5V AA battery (ni-mh, alkaline)
• 80mm (Length) X 16.6mm (Diameter)
• 21-gram weight (excluding batteries)
• Premium Type III hard-anodized anti-abrasive finish
• Waterproof to IPX-8 Standard
• Toughened double ultra-clear glass lens
• Reliable twist switch
• Candle mode (Capable of standing up securely on a flat
surface to serve as a candle)
• Accessories: key ring, lanyard
http://www.fenixlight.com/viewnproduct.asp?id=69
what do you think?
(The Fenix website was updated a couple hours ago - this morning there wasn't any LD15 !)
what do you think?
