Fenix LD20 and Quark AA2 - interchangeable parts?
LightningFox
Los Angeles
Here goes another question for the CPF experts:
Fenix LD20 and Quark AA2 -- are their accessories interchangeable?
Both lights are superb (I'd get either one) and their accessories are excellent, however neither one has the accessory set I'm looking for:
- Fenix diffuser tip (turns light into a lamp)
https://www.fenix-store.com/product_info.php?cPath=22_27_38&products_id=339
- Quark prism (turns light into angle-light, for hands-free work)
http://www.4sevens.com/product_info.php?cPath=297_304&products_id=1973
Would the Quark prism work on the LD20?
Would the Fenix diffuser work on the Quark AA2?
My Quark Prism Kit fits my LD10 head fairly well, but that's the only aftermarket bezel accessory I have for either light. So beyond that, :shrug:
The fenix LD-PD red filter doesn't fit the quark head; it's hard plastic and the Fenix head is slightly smaller... I did have one with a crack in it, so I put electrical tape around it and could use it on my quark AA... until it fell off somewhere in the woods.
Good idea, I never thought of trying quark accessories on the Fenix.
The fenix diffuser tip doesnt work on the Quark head but Im using the Quark prism on my Fenix L1D, meaning believe it will work with the LD20.
What do you mean the diffuser tip doesn't work on the Quark? is the diffuser too narrow or too large to fit on the Quark?
my LD20 lives inside a quark AA2 holster, but I'm not sure if that counts as an accessory.
for all you guys that have a Quark AA2, can you measure the circumference of the head of the light in millimeters?
I use the fenix red lens on my quark aa2 , just sand off the inside a little bit. It did 'nt take much, reallt easy.
The fenix ld20 head is 21.50 mm and the quark aa is 22.05 mm.
Fenix accesory tips are too narrow for the quark, unless you want to crack them and put some electric tape to keep them on, but you risk loosing them and it doesn't look good... but it kinda works
Quark AA / AA^2 = 22 mm OD at the tip of the head
I can get my fenix diffuser to fit on my quark, but the fit is very, very tight. With a bit of sandpaper I think you could achieve a fairly reasonable fit of the fenix accessories on the quark. It's harder to make something smaller though, so I don't think you'll have luck getting the quark prism onto the Ld20, at least not very well.
I used a dremel to the LD series diffuser tip, so I could use it with both Fenix LD10 and 47 Quark AAw.
I also have the Fenix headband, great thing and works with both Fenix LD10 and 47 Quark AAw(with clip)
