Chicago X
- Joined
- May 6, 2010
- Messages
- 439
Hi all,
I just received the new LD40, ordered from Mallard Spring. This is the newest 4 x AA battery offering from Fenix, and my second Fenix purchase after the 8 x AA TK40.
Please excuse the less-than-stellar Iphone pics....
Included in package:
This flashlight uses a Cree XP-G R4 in neutral-white, rated at 248 max lumens. The reflector is smooth, and the die well-centered.
Size compared to iTP A6 Polestar:
First Impressions:
Taking the light out of the package, the first thing I noticed was the very heavy head in relation to the body. I was expecting it to be top-heavy with batteries, but it turns out to be very nicely weighted when powered with NiMH batteries (recommended in instructions.)
The holster is a very nice piece, with a secondary Velcro attachment. This allows for belt carry without removing one's belt, or attachment to a non-removable object/strap. Of course, there is a regular belt loop as well.
The head is anodized aluminum, mated to a molded plastic body. Battery insertion is achieved through removal of head, which requires quite a bit of initial effort. The threads on the plastic body are noticeably coarser than on most metal-on-metal threads of a similar diameter. My LD40 came with lightly greased threads.
The battery holder is asymmetrical and unidirectional.
Hand-feel is greatly inferior to the TK40, and the battery carrier is flimsier than the oft-criticized A6 Polestar unit.
After installing the recommended NiMH batteries (no 14500s!!!) there is a noticeable rattle in both the switch and battery carrier.
There is a bit of flex to the main housing when empty and head is off, very little when fully assembled.
The shape does fit my hand nicely, and the design has one less potential point of water intrusion than a TK45, and the same number as a TK40 - with one more button.
Operation:
This light has two buttons (see above): one larger, rubber-coated forward-clicky and one smaller, electronic clicky. Both buttons require firmer pressure to operate than the TK40's single button.
The larger button first provides engagement on the way down its longish travel, allowing for signalling, before a loud "click" fully energizes the light. The LD40 remembers the last illumination level when turned off.
The LD40 has four distinct illumination levels:
The smaller, bare metal button has three functions:
The flashing modes are as follows:
Now, some more subjective comments:
The LD40 is a good thrower, and should be considering the size of the reflector.
I'm not impressed with the beam. At all levels, it contains a distractingly dark center artifact and very ringy beam. It resembles a 3-level bullseye or target.
The strobe function strangely fluctuates between a very fast strobe for about two seconds, then a slower strobe for about ten flashes. This pattern repeats.
The Good:
The Bad:
The Ugly:
Overall, I feel this to be a near miss from Fenix and will likely be excising this light from my collection. Please PM me with any trade ideas.
Beamshots to follow.
- LD40 flashlight
- Braided lanyard, similar to TK40 example
- Extra o-ring
- Very nice holster/sheath
- Instructions
- Warranty card
First Impressions:
Operation:
- Low - 4 lumens
- Medium - 43 lumens
- High - 110 lumens
- Turbo - 248 lumens
- Changing illumination level
- Toggling between normal and flashing modes
- Changing flashing modes
- SOS - 64 lumens
- Slow flash - 64 lumens
- Strobe - listed at 278 lumens
The Good:
- Good thrower !
- Good runtime on 'Turbo' setting (3 hours + unverified)
- Nice, useable low
- Excellent holster
- "Hidden" strobe modes
- Is much cheaper than TK40
The Bad:
- Feels much cheaper than TK40
- Can't tailstand
- Alkalines NOT recommended
- Odd strobe
- Output for size or battery configuration not stellar
The Ugly:
- Rattle(s)
- Frame flex
- Ugly, ringy beam with dead spot in middle
