kj75
Fenix LD75C: 4 x XM-L2(U2) + 1 x RGBW LED, max. 4200 lumens, 4 x18650 / 8 x CR123A, (beam)shots and comparison
Often discussed, several times shown on trade shows: The new Fenix LD75C. This is the brightest light ever made by Fenix, the first that reaches more than 4000 lumens. But there’s more: Also added to this output king: a high-output multicolor led that gives white, red, green and blue. Fenix gave the change to test this light via a global test campaign, and I was a (happy) one that was chosen. Thank you Fenixlight! Let’s have a closer look at this interesting one!
the new Fenix output-king
“let color matter”
powered by 4 x XM-L2 and one multicolor XM-L LED
As usual, we will start by having a look at the (output) specifications, given by Fenixlight:
· Utilizes four Cree XM-L2 U2 LEDs and one XM-L color LED with a lifespan of 50,000 hours
· Powered by 4 rechargeable Li-ion 18650 batteries or 8 CR123A lithium batteries
· Dimensions: 158mm (6.22’’) x 52mm (2.04’’) x 74mm (2.91’’)
· Weight: 430-gram (15.16oz) excluding batteries
· Digitally regulated output - maintains constant brightness
· Double circuit design for flexible power options and better reliability
· Reverse polarity protection guards against improper battery installation
· Over-heat protection to avoid high-temperature of the surface
· Total 3 side switches for ON/OFF and output selection
· Made of durable aircraft-grade aluminum
· Premium Type III hard-anodized anti-abrasive finish
· Toughened ultra-clear glass lens with anti-reflective coating
the output specs:
Unboxing:
Short story this time
: Because this was a testing sample, it came without carton, accessories and manual… Luckily local importer knivesandtools shipped it to me in a sturdy carton, thanks for it!
Impressions:
First impression: A (nice) mix of Fenix-lights I’ve seen before: TK75, LD60 and a bit TK61. So, a real Fenix member. Allthough this is a sample, the build quality is excellent. It feels all sturdy (and also a bit heavy), and will last for years. Anodizing is well done, I could only find some chips, most at the cooling fins. Also on the bezel you can see this light is “used” before. I’m sure later “stock” versions don’t have this issue. Also two chips found in the reflector, and two leds little off-center. Some engraved marks look a bit faint. The threads are well machined, are little lubed and run smoothly. Inside the tube and tailcap it looks all ok. Some (maybe) personal improvements for me: a (better) anti-roll design a “double” lanyard-holes. Overall, this is what you can expect made by Fenix: a durable, high-quality light.
a mix of some successful Fenix lights
balanced proportions
impressive: the head with total 5 leds
well machined and finished
Multifunctional light
with good grip
compact, easy to handle with
with recommended cells
no anti-roll….
but steady tailstand
detail picture
individual reflector for the color-LED
a color led-close-up: mind the special reflector
new operation with three buttons
excellent finishing and anodizing
the new “sun-button” is positioned little below
a look into the battery tube
light can operate with two 18650’s or 4 x CR123A’s too. Mind to insert them at this way..
with two cells, output will be out of two main leds. Color led’s output is equal, but runtime less
waterproof according to IP-X8
Interface:
From a light that has 5 leds built-in and is driven by four 18650 cells, we can’t expect a lightweight. But anyway, it fits good in the hand, you have enough grip and the LD75C is easy to handle. The three button have a new shape and print, the instant button is placed slightly lower. In darkness, this lower placed button will help you also to right upper. Short press on lower “sun” button will give instant-strobe, longer press than one second instant turbo (4000 lumens). You need to deactivate this by a short click, it has no momentary. Press and hold the right upper button for white light, cycle through the modes by short clicks. The same for the left upper button, but then you’ll have color modes. New feature is the power check: quick double press the C-button to show current voltage: Blue (high) Green (good) Red (low) Red flashing (critical). Innovative, I’ve never had this before!
Modes:
By pressing the on/off button (and you click to cycle) you enter the 5 “normal” white modes: ECO > LOW > MID > HIGH > TURBO. Press (and short click) the C-button for the 5 color modes: WHITE > RED > RED SLOW FLASH > RED/BLUE STROBE > GREEN > BLUE. The LD75C memorizes last used mode. A short click at the lower “sun-button” will give Strobe, press and hold this button for more than one second to enter turbo mode. Short click the sun-button for off. All combinations are possible, (a great point here!): for example Turbo + Red/Blue Strobe, White eco + Red, Green + Strobe. NOTE: to reach the maximum output, you’ve to choose white color + turbo mode, to reach to maximum output of 4000+200 lumens. Instant turbo works only with 4 leds. Because this bunch of modes and combinations you have this is an interesting light for hunting, rescue and so on. Strange thing is the lack of a SOS-mode. Wish it had a beacon mode too…
Tint:
No surprise here, the XM-L2 (U2) leds have a coolwhite tint. I’ve compared it to the Olight SR Mini, that has a bit more neutral tint.
Size comparison:
As for a big Fenix, it is real compact. It has almost the same dimensions as the LD60. Also compared this one to this multicolor-brother TK32 and the huge thrower TK61.
CR123A, 18650 cell, Fenix TK32, LD60, LD75C and TK61
TK61, LD75, LD60 and TK32
the heads: all main-leds are XM-L2(U2)
and the tails
The beam:
LD75C has a nice “all round-beam”: A rather big hotspot, that makes the light a decent thrower; also a big corona and a lot of spill. Scroll down to see the outdoor shots also….the beam is really impressive! Nice feature also: Use the white color led for only a “floody” beam. As earlier said, you can mix these ones until you’ll have your perfect beam
Projected on a white wall, distance to the wall about 0,75 meters. Because there are a lot of modes and combinations, only gif pictures here.
camera settings: ISO100, F/2.7, 1/125 sec, WB daylight, 35mm
white modes plus white color led (to reach maximum output of 4200 lumens)
the color modes
some combinations of white and color
And now, let’s see what this light brings outside…. Again, at first, the white modes. After that some gif-pictures of the color modes and some combinations. Last (but not least) compared to the LD60-brother and the Nitecore TM06.
camera settings: ISO100, F/2.7, 4 sec, WB daylight, 35mm
animation
animation of the color-modes
LD75C against LD60
LD75C against Nitecore TM06
Conclusion:
The brightest Fenix I’ve ever had! Compact, impressive output, also for the color leds. It’s a real Fenix, that means built quality and finishing are excellent. Because my light was a pre-production sample, I found some little “user traces” and some leds could be centered better. I don’t know why a lock-out mode is missing, Fenix should add this in future. Also the lack of an SOS-mode is strange. Can you restore beacon mode too, Fenix?
Overall, this is one of my favorite big lights, I played around for hours with it now. So, if you’re looking for a high quality output-king that has decent throw and powerful color-modes too, this will be a good choice.
Thanks to Fenixlight and knivesandtools for sending me this sample!
“let color matter”
the output specs:
Unboxing:
Impressions:
with good grip
no anti-roll….
detail picture
Interface:
Modes:
Tint:
Size comparison:
and the tails
The beam:
the color modes
animation
LD75C against LD60
Conclusion:
