wojtek_pl
Hi,
as I'm little obsessed with new generation of LEDs I put them into my different flashlight.
So I took perfectly good Fenix P1 with perfect Luxeon and modified it... It works after modification and I call it Success !! 😀
I cannot see much difference in brightness but I measured lower current.
Standard Fenix P1 from protected RCR123 3.7V 750mAh - 0.66A
Modified Fenix from the same battery - 0.45 A
So runtime will be much better.
Also the beam is more flood type as I cannot set right focus without taking the reflector out and shimmering it a little. That's for later.
So here are beamshots:
Left Fenix P1D-CE on medium powered by standard CR123A, right - modified Fenix P1 powered by RCR123
Left Fenix P1D-CE on medium powered by standard CR123A, right - modified Fenix P1 powered by RCR123 - underexposed picture.
Left Fenix P1D-CE on HIGH powered by standard CR123A, right - modified Fenix P1 powered by RCR123
Left Fenix P1D-CE on HIGH powered by standard CR123A, right - modified Fenix P1 powered by RCR123 - underexposed
Left Fenix P1D-CE on HIGH powered by standard CR123A, right - modified Fenix P1 powered by RCR123 - more underexposed
