mchlwise
- Joined
- Apr 28, 2006
- Messages
- 949
I was one of the first to pre-order the Fenix P2D, and I've had it now for about a week and a half.
After pre-ordering the light, I went looking for 3.0v RCR123s. On kaidomain I found these batteries:
http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=1260
and this charger:
http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=998
I ordered them on 4/5/07 and received them today. I figured for $10.02 shipped, it was worth taking a chance.
I was a little anxious after seeing posts where RCR123s were really tight or didn't fit in the P2D. These... slid right in! They're as near as I can tell exactly the width of a standard 123, and about 1mm shorter. :shrug: No complaints.
The other thing I was worried about was retaining the different modes. I got those particular batteries since they're advertised as 3.0v, but I'd heard they come off the charger at more than that. I put the battery in the charger and fired it up and waited for the light to turn from red to green. When it did, I threw the battery in the P2D.
In "general" mode, it came on at about "high". Half-press and went to about "high", another and it went to "high", then s.o.s. Tightening the head for Turbo was brighter, but there was no lo or medium. Bummer. :sigh:
So I decided to experiment. I turned it on in Turbo, and left it on for 10 minutes, and tried again. After sitting on a desk that long in Turbo it was pretty warm, but far from too hot to hold. At the 10 minute mark, in General mode, it came on at about medium, half-presses and it went to high, then went to high, then s.o.s. oo:
So I turned it back on in Turbo for another 5 minutes. I went to General mode, and Eureka!, it came on in low! (or at least pretty close to it). It might be a little brighter, but there are definitely 3 distinct levels and low is pretty close to where it's supposed to be.
So after using it for 15 minutes in Turbo, the voltage was down enough for it to drop back into regulation, and I've got all modes! :rock:
Unfortunately, I don't have any means to measure voltage so I don't know what voltage it came off the charger at, or what it had to drop down to for it to be back in regulation. I don't have any clue how the RCRs are going to do with runtime either, but they are advertised as 1000mah, so they should last a while.
:candle:
The end result is I'm very happy. :rock: I've got rechargeable batteries that will run my P2D, which = guilt free lumens. I use it on Turbo mostly anyways, and as long as I don't need low for the first 15 minutes of use, everything is great.
and this charger:
:candle:
