saftydiver
- Joined
- Apr 8, 2015
- Messages
- 12
I thought I'd share my impressions of the Fenix SD 10. As a dive instructor I look for sturdy lights that are easy to use, reliable and bright. It also will be in the water 3 to 5 days a week all years round (I live in Florida).
The SD10 arrived early in the week complete with extra O rings and a nice lanyard. Because I won't use new equipment when I have students I had to wait until Friday to dive with the light.
The SD 10 is very well made and finished.It looks like double walled aluminum that would seem to be able to withstand depths to 100m. It has a very robust on/off switch activated by rotating the back cap and positive knurling on the barrel which is important when gloved.
My dive was shallow but long (2 hours and 26 minutes). I entered the water about an hour before dawn. I dropped down and turned on the light...the 930 lumen beam has good throw (viz was 60+ feet) without too much of a hot spot or too wide a beam. I could see close up and far without problems. While I did vary the beam intensity to try it using both the end cap and shake method, I kept to usually at the high setting to test battery time. I'd imagine it was on for about 80 minutes of the dive. The light functioned without issue.
There are a few pros for this light. As I said it is very robust and I found it easy to manipulate underwater. The three levels are handy, especially when looking at critters. This light is also very compact and weight isn't an issue. These are important issues for divers. It clipped easily to my BCD and was out of the way until needed. One can't ask for more from dive equipment.
I'd thought the "motion" adjustment would be a minus but I found you could not accidentally get the light to change and only needed one firm shake to activate it.
A couple of very minor things I'd rate as cons and they are minor indeed. The gasket around the outside of the head of the light really serves no useful purpose and likely won't stand up to long term dive conditions.It almost came off a couple of times as I deployed the light. The included lanyard while nice isn't really sturdy enough for everyday use. I replaced it with a dogclip, split ring and sturdy cloth and rubber lanyard.
This light will undergo further testing and will be along on some deep tech dives next week but I think it is just what I'm looking for in a dive light.
This little guy likes it too:
Finally I'll say that while it wouldn't make a great pocket carry, it wouldn't be bad in the glove box.
