jlomein
I just got my clipless Fenix T1 in the mail today, and overall, am pretty satisfied with it.
Some things I do question. First, the LED is very deep in the bezel, and it appears as if most of the LED is recessed behind the reflector, instead of sitting level with it. I have seen pictures of other T1's (like WadeF's below) that seem to have the same issue. Is this normal? Wouldn't the spill light be brighter if the LED was more level with the bottom of the reflector?
Another concern I have is that the two stage rotating bezel has some contact problems. To get to Turbo mode, the bezel must be screwed very tightly. If it is not, it will hit an in between mode where it is brighter than the Low mode, not quite Turbo, and tends to flicker. I have not read about anyone else having this issue.
Finally, my Cree LED is not completely yellow. I thought Q5's had the entire LED dome tinted yellow? Mine has a yellow die, but the dome is clear/translucent.
I'll post pics later when I get a chance.
