Interesting to see that this puts out a similar amount of light to the Dereelight CL1H, which was using a smooth reflector and the Fenix uses a textured one.
Textured v's textured and the Fenix is a clear winner.
That is not my experience with the T1; it kinda flickers (more like strobes or pulsates) on high when the batts reach that threshold where they can't keep up with the high mode. When I reach that point, I simply switch to low mode, and the strobing goes away.The regulating circuit is the T1 is slightly different from that in the P series for example as it doesn't start pulsing as the battery voltage runs down. The T1 simply gets dimmer.
Regarding the CL1H/DBS pills, yes i did try with and without the rubber o-ring, and even without the thin plastic disk. Not a good focus, the lip on the brass pill itself is sligthly higher.
Yeah, I always move the beam around to find the brightest spot and record the highest LUX value I can find in the hot spot
Also while the Dereelight pills can be interchanged, I was informed the pills are different. If you have a DBS pill you need to remove the o-ring from the back of the CL1H reflector's. If you look, you should see some kind of rubbery stuff on the back of the reflector where the pill screws in. Removing that I figure allows the DBS pills to screw in farther, allowing for the hot spot to be more focused, etc.
