Fenix T1 size comparison to Surefire E2E. pictures?
passive101
I currently use a Surefire E2E as my EDC and it is also used in conjunction with my firearm. I like the size of it, but there are bigger and better things now.
How does the size of the Fenix T1 compare to the surefire E2E in size?
Should I get the T1 or should I wait to see if they make a smaller version of it first? I don't want to go any larger.
Don't have any photos, but picture a 6P with a KL3 head and you've got a good idea of the size of the T1. Quite a bit bigger than the E2e.
Hope this helps
http://www.cpfmarketplace.com/mp/showpost.php?p=2090332&postcount=1
I also have it pictured with others here
The Fenix T1 is more comparable in size to the Sure-Fire C2 than the E2E. The E2E is much smaller than the T1.
Thank you for the picture of it. I don't really want to go larger then an E2E for every day carry. This light works fine for the few times Id require it for right now.
I wouldn't throw in the towel just yet. Have you tried Lumens Facoty's 150 lumen EO-E2R with rechargeables? This is my current set up for the E2E. The LED option for it is still available if you so choose.
How much would it cost for the led drop in option? How long would it output 150 lumens?
What's the runtime on the 150 lumen E0-E2E?
