Fenix TK20R V.2 or Nitecore P23i? Or something else? (EDC in holster on belt, for general use and potential self-defense)
Prof.Dr.FlashlightNewbie
Hey, I'm currently trying to decide between the Fenix TK20R V.2 and the recently released Nitecore P23i. I want a bright flashlight to carry in (ideally a supplied nylon-) holster on my belt all the time.
The light will be used anytime I need some light, but in the unlikely event that I get into a self-defense situation, it should be useful for that as well, which is why I like the idea of a dual-tail-switch for one-handed operation with direct access to strobe (and ideally also to turbo...).
I like the 3000 lumens and the relatively tight beam that those two lights have, both for effective use at long distance and for their peak brightness to blind in an unlikely yet possible self-defense situation.
The light should come with a powerful battery that can be recharged in the light.
Given that, which of those two lights would you recommend? On a YouTube video for the P23i someone wrote that his light has a dark spot in the middle of the throw... that's something I would really like to avoid. Is that typical for that Luminus SFT-70 LED or does the TK20RV2 have a nice beam without a dark spot or any other artifacts?
Or is there maybe another light that I should consider?
Thanks in advance for any help. :)
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
_X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
_X__Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
_X__I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
_X__MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
_X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
_X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
_X__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
_X__I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
_X__I want search and rescue type illumination (800+ lumens).
_X__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
_X__Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
_X__150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
_X__90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
_X__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
_X__Other, please specify: Two tailswitches for one-handed operation. Direct access to strobe. Ideally also to Turbo...
____A simple on-off with only one output level is fine for me.
_X__I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
_X__I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
_X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
_X__IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
_X__In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_____________________________________________
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
_X__Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
Silly Rabbit
Ottawa, Ontario
I just picked up a Fenix TK16 v2 (with the E02 as Christmas promotion). I was actually debating on this and and TK20. I figured I'dd save a few dollars and also get the E02 thrown in. I haven't seen the TK20 in person but when I played around with the 16 I was really impressed, a solid light beam, alot of light for the size. I also like the 2 tail switch operation of it.
So going strictly on my uneducated opinion owning the 16, I say you would be happy with the TK20. :)
..... you would probably be happy with either the lights your looking at, lol.
Hooked on Fenix
Honestly, I'd say neither. The Nitecore has a low of 50 lumens. The Fenix has a low of 30. A tactical light should have a nice and bright high setting for blinding an assailant, but it also should have a good low to avoid detection. Let's say you blind someone trying to hurt you and then run. Now they are chasing you and you're carrying a bright flashlight that shows them exactly where you are. You need to switch to a low enough setting to avoid detection while still having enough light to not trip and hurt yourself. 5-25 (15 for Surefire) lumens is what you want for a usable low setting. Another light to look at is the Klarus XT21X Pro. It doesn't have quite as much throw as your two options (336 meters), but it's 4400 lumens vs. 3000 lumens. Has a battery bank function to charge your phone in case it goes dead when you get into trouble. Also has a 5 lumen low. Price is the same as the Fenix.
Labrador72
European Union
I would rule out the TK22R then: AFAIR the light has mode memory and no shortcut to turbo which, IMO, you'd definitely want for self-defense use.
The P23i, on the other hand, is programmable and has a tactical mode which always goes on in turbo. Even if you accidentally pressed the mode switch, you'd step down to 800 lumens which is pretty bright.
The Klarus recommended by the user above is also a valid option since it has shortcuts to turbo in both tactical and outdoor mode.
