Yes,correct.
Because of thet ,there is Deft-Rev.
If you consider price vs spec which is better option,Tk61vn or Deft-X.
My dream is to have two Deft-x heads and just to swap it for throw or floody beam[emoji3]
It depends on your use.
The DeftX out throws the TK61vn...so if say ultimate range was your primary criteria, the DeftX wins. If range per dollar was the contest, the TK61vn wins.
If we round the throws that each might give you, you are talking about ~ 740 k cd vs 1.1 million cd
That looks like a lot, so, in the field, say using range to 1 lux, its ~ 860 meters vs ~ 1,049 meters.
If using as a search/disaster response light, say to search for survivors, etc, and you use 15 lux, its more like ~ 271 meters vs ~ 222 meters.
That CAN make a difference between resolving a leg from a branch at that kind or range in a search, and if you're the victim being looked FOR, YOU'D like the searcher to have the brighter light if you're ~ 250 meters away and bleeding out.
If I am equipping guys for a search though, and I can get THREE 740 k cd lights, or ONE 1.1 M cd light, I would feel that the three 740's could search a larger area more quickly overall, etc.
If I have to patrol a 500 meter wide river or flood zone, etc, and am cruising down the middle to search both banks at the same time, I'd better have the DeftX (Or other search light with that magnitude cd) to be able to hit both banks with 15+ lux from the same point.
So, sometimes the task dictates the best tool for it.
