I guess I'll have to buy some of those AW's, I've got a few 14500 aw's and there great. I purchased my panasonics from this guy on ebay.
http://www.ebay.com/itm/4er-Panason...rElectronics_Batteries_SM&hash=item3a7916d4f3 Man i hope i didnt get ripped off. This flashlight has been a money pit. kind of regretting trying out hid's
Just looking, those cells at ebay are not protected, you could potentially damage them in series. (like with this light) in the first full discharge. It is at the link below, where it is indicated, that the running voltage of the HID can go well below any 4S li-ion discharge, and Protection would be a nesessity. (unless you watch it like crasy)
On the other hand, not having protection, it shouldnt be cutting out, assuming you charged them proper, and didnt run for too long, and this is your first runtime testing.
Your final voltages indicated, show that they were not deep discharged, assuming that was all of them, and your still getting that.
you can get protected panasonics with ~6amp, and also with ~10-12amp style protection on them, so on paper you should be able to get properly protected panasonic cells that will strike and run that.
http://www.candlepowerforums.com/vb...Am-Blown-Away!!-**NEW-BEAMSHOTS-ADDED**/page2
IMSabbel indicates the starting amperage can be 8amps. So you would want to get protected cells with the higher protection amperages.
HKJ has (thankfully) tested a number of the 3400 panasonic re-wrapped protected cells, and tells of the protection trip amperages.
http://lygte-info.dk/review/batteries2012/Common18650IndividualTest UK.html
as far as the problem, i do not know the solution. i was just looking at whats up. the e-bay seller seems legit enough, it could be a battery issue, but i do not know. Here i would just fire up the light with the bench power supply. Or use a more powerfull battery wired in cleanly and carefully to test.
see also
http://www.candlepowerforums.com/vb/showthread.php?354135-AW-3400-18650-melting for battery length issues
