Hammer Train
Banned
- Joined
- Sep 3, 2008
- Messages
- 716
1. SOLD Blue 3D MCE Mag with MCR reflector.
The host is a blue 3D Mag with a D-Bin Neutral white 'J'vf P7 on a DHS heatsink and runs off 3*D-Cells.
However rather than a modified mag reflector or similar I decided to use a modified McR18 reflector so that I could put a lot of v10 glo-powder in 2ton epoxy around it to give a decent glow effect that puts out a little light by itself. The result is a light that has a less defined hotspot than using a stock mag reflector so the beam is more 'floody'. However I was very pleased with how the beam turned out, still with a hotspot but the spot is a quite big!
PRICE - SOLD FOR $40
2. SPF - Five-Mega 1.5D Mag-D host in purple. Yes it's very bright & flashy. I'll include a custom made 3*17500 (serial) cell holder made for me by mdocod and 3*17500 AW cells that have only 1 charge on them - $150 - LET'S MOVE THIS, TODAY ONLY - £60 / $100
3. SOLD FOR $125! Or how about an OSTAR Mag, with custom made switch and one-off custom made led mount giving amazing heat-sinking. The led runs from a maxflex2 set to high only (and can't be changed for some reason, but works on high beautifully lol!).
Some kind of scalloped bezel on this one, top quality lens, custom aluminium reflector, the switch protrudes lower than the switch hole (as you can see from the pics) so the standard rubber boot won't fit without glueing - I'll leave this for you to do! Also the tailcap almost shuts completely but not quite due to the extra length of the custom switch however the tail and spring have been modified so that this isn't a problem electronically.
I'll include a quality (FM?) 4*15670 holder and 4* AW 15670 cells as shown in the pic.
No idea how to price this one as it is a one-off. Please can someone help me out with an offer. $175 - SOLD FOR $125, as that was the offer.
4. SPF incan modded 4C maglight with Luxluther eneloop pack and charger.
Over 2000lumens, it's a user but astonishingly bright.
$85 - REDUCTION TO £39 / $70
5. From a new batch of Betalights, with a GID paracord attached. I have since also put GID glitter powder (Glo-Inc) on the outer of the trit cover.
Let's say $65 - REDUCED TO £35 / $60
6. SPF R2 DEFT - £225 / $375 - this is the brightest of the 3 that I have held over the past few months, hand picked for the warmish tint compared to the rest and outstanding throw. Never thought I'd let this go but needs must...
THE FOLLOWING ARE ONLY TO BE SOLD WITH ONE OF THE LIGHTS ABOVE:
7. What about a brushed ss bezel and a matching modded tail for a D mag. The tail has a tailswitch installed using mag parts.
$50 for the pair - Bezel now sold, NOW £15 for the tailswitch delivered.
8. Anyone want to mod an HID light?
Here are two 4300K HID bulb kits. $40 for the pair - NOW $25 for the pair
9. SPF A couple of D-Lions and a compatible charger anyone? These fit the mags I have for sale too.
$35 - OK, MAYBE $20 for the cells only?
10. SPF 4* New AW 17670 - $35 - NOW $25
