Finally...a 2.8A Driver for the SSC- P7!!! (4xAA or 32650)
phreeflow
Just a heads up...SSC-P7 8x7135 2.8A Board....is now available here: http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=4338
Can't wait to see the new builds/mods people will be doing with these!!:popcorn:
Here are the specs (from website):
Dimensions:
- Current regulated at 2.8A
- Gives 1+ hour current regulated (2.8A) output with four Eneloop AA
- Gives 3+ hours current regulated (2.8A) output with single protected KD 32650
- Measures 17mm in diameter, and 6mm in height
- Single light mode only
- Designed for SSC P7 LED for maximum output 740lumen-900lumens (C bin)
- 1xVin+, 1xVin-, 1xLED+, 1xLED-
- Prewired, ready to use
- Custom made only, ships in 3-5 days upon ordering
- Input voltage 2.7V-6.0V, buck circuit
I agree.
I ordered a couple of these plus P7's 24 hours ago.
Can't wait to have a play but will have to be very patient since (from my very limited experience) delivery to Australia from that Dealer can be very slowwww. If I make anything interesting I'll post it.
What an ugly bodge, 2x 1.4 drivers pushed together...where does the +'ive battery terminal go?
I'd rather just do 2 of them separately so that they can be heatsinked better. In this set up, you have to either just have the driver floating in your light, or only one side of the board well sinked. More on this driver in the Electronics section.
