Sold/Expired FINISHED (after shipping) Min-T CNC Bike Light
ktronik
ktronik
Australia
Re: Taking Orders/Payment : min-T CNC Bike Light
Progress report:
So far I have 5 units fully built & ready for programing. Hope to ship these Monday / Tuesday.
The other 5 units have their faces done & ready for wiring.
It was a lot more work that I first thought.... :whistle: 2 weeks was a bit optimistic. As this is still a proto run, I forgot the first few would be a bit slower, till I got the build process down pat.
I have gone over board a little on the water proofing, this time... as its a new product & don't have a lot of rider feedback @ the moment...
I think of you guys @ CPF as 'test riders'... knowing more than the average light user, you will help me tweek the product so it can be better each run we do... this is reflected in the price you guys are paying.
unfortunately, when the final 'retail sale' version comes out, it will be more expensive... this is mainly due to the fact that the housings are fully CNC made & the cost for Dom to book these huge machines is very expensive & time consuming. @ the moment Dom can only make one light @ a time... & when you are dealing with a cutter that cuts 0.1mm each sweep... the time really adds up...
Anyway, hope to have the rest built & shipped by next weekend...
thanks for waiting
best
Ktronik
W
white light
NJ,USA
Thanks for the update :).It reallly helps on the wait.Things look awsome so far at this point :thumbsup:.
ktronik
ktronik
Australia
Unless people tell me otherwise I will be programing as follows:
DUOMODE: on (L2 low beam)
DRIVE LEVEL: Max 1000ma
SUPER LOCK: off
V STAT LOW: 13v
V STAT MED: 14.3v
POWER ON MODE: off
THERMAL PROTECT: 70 deg
This is the simplest settings for you to get use to the operation of your new light. Once you get use to it, you can change it to MULTI-MODE if you wish.
K
W
white light
NJ,USA
:thumbsup:sounds good,thanks:twothumbs
ktronik
ktronik
Australia
Issues:
As their are now 2 clamp mounting holes, I will be putting the clamp in the main 'underneath' hole (unless told otherwise)
Dom has made me separate 'clamp' tool to squish the o-ring down to tighten the front bezel. It may be that, by hand, you will not be able to remove it, once full tightened down (I will test). so the people that ordered 2 different lens, may not be able to change them... I will get back to you on this when it is done.
Again thanks for waiting...by this week end I will have most lights packed & ready to post. I thought I could have them done last week, but chrissy visitors put a end to that idea...
sadly Darell & I will have to wait a little longer to get their lights built... :(
but Darell should get his in time for chrissy...
with re-glueing the clamps & making the remotes, time has blown out a bit...
but it will be worth the wait for the price you guys are paying...
best
Ktronik
D
dom
Australia Geelong
Good going Ktronik:thumbsup:
Don't try to unscrew the bezel without pressure from a clamp and blocks though - the optic may grip,snap the legs and then :poof: the domes off the LEDs
The idea is to have downwards pressure on the optic when doing up or undoing the bezel -if done properly they won't ever loosen.
PS. Finally got some mount balls done on the NC lathe -which are perfect round -these will be sent to everyone to replace the original ones done with a form tool. The original ones will bed in and tighten up after some use -but the NC ones are much tighter straight away.
They have to be drilled,tapped and flats put on -should do them this weekend and hopefully sent to Ktronik before the min-T's are sent -if not,you will get them later.
Cheers
Dom
P
PhotonFanatic
western Massachusetts
Cheers
Dom
Can we get a photo of this technique so that we'll know how to change the optics on our own? Thanks.
Wow, our first upgrade--even before delivery--now that's service.! :twothumbs
TranquillityBase
TranquillityBase
Fred, the pic is somewhere on this thread...Dom uses a bar clamp (like the popular Quick-Grip, bar clamp) and a block placed on the optic/lens, to compress the o-ring.
P
PhotonFanatic
What, you think I have time to read this thread? :crackup:
Thanks for the heads-up!
D
dom
Australia Geelong
LOL -Thanks TB
You can have a look at the build-up pics at the website Ktronik made ,under "products" on the first page ,for a quick reference.
Though these pix have to be updated for more detail and changing ideas.
Here is a better pic of what is needed for swapping optic.
The rear packer needs clearance so it won't squish the wiring and the front packer needs to be undercut in the middle so only the edge of the optic has pressure on it when clamping.
For homemade packers -a suitable bit of round wood,just a bit smaller than the inner diameter of the bezel,with the middle hollowed out a little would be fine.
For the rear -some square bits of wood -maybe 1" -would also do the job.
Cheers
Dom
TranquillityBase
TranquillityBase
Cheers
Dom
Dom, can you make the flats for the mount ball, for a 10mm wrench?
D
dom
Australia Geelong
Hi TB -no.
8mm is about the biggest i could go -but the larger you go on the nut -the less movement you will be able to swivel. Or the flats will be very small to keep the same swivel movement and you would probably strip the flats trying to do it up.
Why do you want 10mm?
Cheers
Dom
G
Gunnar
I suggest you make the flats in what ever size you want.
But make only 2 flats so they will be so wide so its impossible to fail with an adjustable spanner / wrench.
/Gunnar
D
dom
Australia Geelong
Hi Gunnar
The reason for 6 flats is if 1 set strips -you have another to work off.
Really -there should be no issue of doing these up if you invest in a 1/4" spanner -and how many times will you be taking it on/off?
I don't think there will be room to fit an adjustable spanner either unless you have a slim one -i'll have to try mine at work to be sure though.
Cheers
Dom
TranquillityBase
TranquillityBase
Hi TB -no.
Cheers
Dom
Sorry Dom...
No need for 10mm...I should have asked if you can make the nut metric, instead of S.A.E. sized...I only carry metric tools, in my repair kit.
G
Gunnar
Hi Gunnar
Cheers
Dom
Yea i agree!
I will probably never remove the ball anyway. Put the ball in the rear (allmost wrote: "in my" rear .. :eek: )hole if you have time before you ship mine.
/Gunnar
D
dom
Australia Geelong
If no one is worried i'll make them all 6mm:)
Cheers
Dom
S
SurfHenk
Dom,
thank you once more for the regular updates and improvements!!
I for one prefer a metric bolt, so 6mm would be great!
ktronik
ktronik
Australia
Update:
Big storm up here... must of had a lightning strike on the powerlines... lost a computer, a modem & cat5 hub / switch... lots of stuff fried :sick2: strangely the mac survived so using that...
forgot about the power extensions... do these tonight...then off to dom for the new 'balls' in the mounts...
K
M
mattp94
Cardiff, UK
I've been using my Min-T for a couple of weeks now and it really has been a delight compared to all my other lighting options. The only thing I would have to say is that the 10° optic still gives a very wide spread of light. This is great for lighting up overhanging tree branches and such but I could also do with more of a spot.
My ideal scenario would be to have the 10° light on the handlebars and a tighter spotlight on my helmet so that the spot would penetrate a bit further.
Does anyone know of an alternative optic that would achieve this, or is there a way to modify one of my existing 10° optics to make it more of a spot?
As you can probably see from these questions, I could do with another Min-T shell kit, please put me down for one if you make another batch.
Cheers
Matt
Similar threads
flashlight
Replies
9
Views
2K
flashlight
flashlight
P
Replies
16
Views
2K
delite
D
this_is_nascar
Replies
24
Views
874
this_is_nascar
this_is_nascar
