Finished my first mag mod! (p7)
spc
Troutman, NC
I know, yea yea another p7 mag.. But I wanted to thank everyone for their help. I found these forums very informative. I learned alot!
Its pretty basic...
D bin p7 on a HAIII sink
The host was machined down to a 1d
runs DD off an 18650 with a masking tape sleeve
stock reflector (came out good, no donut and barely any artifacts!)
I ground out a little of the inside of the tailcap, pressed the stock spring back in and bent the tip a little to make good connection to the 18650. The li-ion fits perfectly this way...
the beamshot is with the lights on!
Im officially addicted :tinfoil:
that's a pretty clean beam for a non-stipple. do you see any artifacts in real life?
edit: oops, re-read. yes some artifacts but little. hmm i'm going to have to try a non-stipple in mine for ultimate output.
i got lucky with this reflector I guess, you can only barely see a half of a ring when its aimed at a white wall
Nice work. I love those 1D cut-downs. Would love to do this as my next project but since I'm living in Germany it's hard to find somebody who can maschine the threads :mecry:
well I would do it for ya, but my cordless-drill-in-a-vise-lathe has limited capabilities
You were able to lathe a mag with a cordless drill? Do tell... I am looking at cutting down a Mag for a bike light, would be REALLY interested to know how you got the threading to work in the head.
no no!
I sent the tube to a fellow CPFer. I used my drill lathe to hollow out the tailcap, cut the reflector and the extra plastic off the switch
I attched the reflector to the drill, spun it and held a blade to the area I wanted to cut off. It made a perfect cut. same with the switch and tailcap- except I used a heavey grit sandpaper for the tailcap
