Fireflies E07vn - Compact 21700 Powerhouse R
Wurkkos
Wait really? Based off of beam shots you’ve posted in each thread, the patterns look very similar to me. They both use optics... how could this be? I thought the D4Svn looked like a single large hotspot without hardly any spill.
I learn something new about flashlights every day haha.
b8llzblue
Will the d4s reflector work with the e07? I’m just curious for those that want a d4svn with a 21700. The head is almost identical in size.
Patriot
Arizona
It's interesting that the D4Svn is getting 1250L per W2, while the E07vn is getting 835L per W2. There are probably many factors behind this.
That beamshot looks sweet, Vinh!
Patriot
Arizona
I've both lights but w2 on the EO7, beam is exactly as Vinh described.
Do you have a favorite? Have you been using one more than the other? I'm curious because I don't have a D4Svn, just three E07's with different LEDs.
daffy
Certainly do the beam pattern on the D4S (mines an LED combo not listed anymore on the store) this says it all
Beam wise D4Svn look like a light with reflector. Hot spot corona spill. E07vn has all the output in a large hot spot. "
My D4Svn ends up somewhat neutral, as my eyes are used to CW lights it looks a bit yellow but when out on its own i cant pick it.
The SLN in my triple blue setup has an outward cone of light like the new Olight Pro Warrior, just wish i had chosen green or white too much loss of visual clarity with blue.
Both of the above beam patterns i like but the D4S does throw further than E07, the D4S makes a nice companion if i want a short stubby fat light :)
Prefer D4S and have used it more.
SKV89
The latest batch of E07 I bought switched to a 25deg optic. The previous ones were 45degree. The hotspot is noticeably smaller and more defined.
SKV89
You can PM fireflies but don't expect any answers from them for a few weeks. It's Chinese New Years.
Patriot
Arizona
:eek:oo: Well, this could be interesting! Didn't Vinh try to find some 25° optics a while back and we came up blank? It would be great if they're available now. I'd probably switch out at least two of my E07's.
noboneshotdog
Yes, maybe if they are a direct swap out, he could obtain some and we could in turn buy them from him......?
SKV89
While talking to Fireflies about offering face masks to us, they said a customer in the US is having problems with his two E07 with Osram and asked if I want them and see if I can figure out the problem. I received them and washed them down inside out with detergent and rubbing alcohol as I do for all my new lights and put it to the test. Surprisingly both work flawlessly and I ended up with two amazing lights for free!! woohoo!!! :D
I tested them using the Texas Ace Lumen Tube calibrated with Maukka lights and Sekonic C-800-U spectrometer. Output measured at 2s from turn-on.
Fireflies E07 Osram Gray UnitTurbo6,819 lumens6648K-0.0028 DUV69.9 CRIBlue light relative amplitude 1.00-16.2 R940.9 R1264 Rf96 Rg30T
Fireflies E07 Osram Gray UnitTop of Ramp2,353 lumens6320K-0.0007 DUV67.7 CRIBlue light relative amplitude 1.00-25.6 R938.8 R1262 Rf96 Rg30T
Fireflies E07 Osram Gray UnitTurbo6,466 lumens6532K-0.0024 DUV69.3 CRIBlue light relative amplitude 1.00-18.7 R940.2 R1263 Rf96 Rg40T
Fireflies E07 Osram Gray UnitTop of Ramp2,310 lumens6328K-0.0008 DUV67.4 CRIBlue light relative amplitude 1.00-26.1 R938.7 R1261 Rf97 Rg40T
Fireflies E07 Osram Silver UnitTurbo6,991 lumens6497K-0.0019 DUV69.7 CRIBlue light relative amplitude 1.00-19.0 R940.3 R1264 Rf96 Rg30T
Fireflies E07 Osram Silver UnitTop of Ramp2,397 lumens6267K-0.0003 DUV67.6 CRIBlue light relative amplitude 1.00-26.6 R938.7 R1262 Rf97 Rg30T
Fireflies E07 Osram Silver UnitTurbo6,500 lumens6452K-0.0013 DUV69.6 CRIBlue light relative amplitude 1.00-20.3 R940.1 R1264 Rf96 Rg40T
Fireflies E07 Osram Silver UnitTop of Ramp2,267 lumens6244K0.0001 DUV67.8 CRIBlue light relative amplitude 1.00-27.1 R938.6 R1262 Rf96 Rg40T
Output is very slightly higher using Samsung 30T over 40T. I think 40T is the better cell so it doesn't get so hot so fast. Output is a bit lower than I measured the E07 XP-L HI v2 5A. The tint is very pure white on Top of Ramp and Turbo modes. On lower output, it is a good bit above the DUV but due to the high CCT I don't notice the green.
