moldyoldy
Moderators, move this thread as necessary.
For those of you who read German, check out the Focus.de article in the Auto section on fires in battery-operated vehicles, from Porsches to Motorbikes. The batteries discussed were Lithium-Iron-Phosphate, Lithium-Polymer, and Lithium-Ion, The point for us flashaholics is to pay attention to the proper use of our Lithium-xxx cells and to use a charger with the correct charging algorithms.
http://www.focus.de/auto/ratgeber/s...ch-wird-die-elektromobilitaet_aid_774866.html
A brief synopsis of the Focus.de article follows:
ie: A Porsche GT3 that used a Lithium-Iron-Phosphate battery pack for the electric starter to save weight was destroyed when the battery pack caught fire during charging in a garage (photo included). An investigation by Auto Bild implicated the battery pack as the source of the fire. Porsche is withholding comment, but claimed that an incorrect battery charger was being used.
ie: The firm Fisker-Karma produces a hybrid vehicle Karma that caught fire in a garage. NHTSA is still investigating as to what started the fire. however the firm recalled over 200 vehicles to change out the battery packs.
ie: In May 2012 in Shenzhen China <<where many of our flashlights are made>>, 3 Chinese citizens died when their Elektro-Taxi E-6 was hit from the rear which immediately triggered a fire in the Lithium-Iron-Phosphate main battery. Chinese authorities are still investigating.
According to a battery expert at the Ulm (Germany) research center ZSW, there are 3 elements in a Lithium-Ion battery that are pertinent: The Cathode - which in the case of the Lithium-Iron-Phosphate battery is not critical since this cathode material cannot thermally decompose. The carbon-based Anode can react under certain circumstances (and overheat). The Electrolyte is an organic solution which can catch fire either by opening the cell, or if some other component overheats.
ie: The Chevrolet Volt has had problems with fires. In one case, the Lithium-Ion battery pack caught fire after a crash test. In another case a Volt caught fire 21 days after the crash test. In that case, the operator was not paying attention after the crash, did not discharge the battery pack per protocol, and coolant leaked out leading to the Lithium-Ion battery pack overheating. In another case, NHTSA and Chevrolet technicians conducted a variety of tests on the T-shaped battery pack (in the Volt). In one case, the battery pack caught fire a couple hours after test. In another case, the battery pack caught fire 7 days after a test.
ie: the electric-assisted bicycles called Pedelecs have also suffered damage to the bikes and to the riders. In one case, a Lithium-Polymer battery was seriously overloaded and overheated. when the rider attempted to put out the fire, the fire flared and the rider was seriously burned. However in this case, an investigation showed that the battery pack was manipulated/changed by the owner when the battery management pack was jumped which monitored the charge state of the cells and temperature. Worse still, the owner used a non-standard charger.
The general feeling amoung battery experts is that battery packs developed by small companies will most often be implicated as a fire source, not from large companies. The larger companies spend a lot of money in crash tests and sealing the battery in a well-protected housing. In the case of a collision, battery power is instantly cut off.
Comments were made at the end that there is simply insufficient long-term experience with the Lithium-Ion technology.
<<Edit: I understand that an accident which somehow deforms the battery compartment can cause a fire. However the time delay in the fire starting after the incident is very disconcerting!>>
