usdiver
Thanks guys, the keepowers are indeed protected and about 35mm if not more. My aw s are not protected but I can run the keepowers in 2 of the custom tubes I had made. (2mm longer than factory).
The TMax and the Tomahawks both need 2 batteries due to voltage. 1x 17670 will work for a bit in the 425 Tomahawk but the TMax immediately goes onto lockout mode and won't work. The 26650 works in the 425 but not for long.
This is its way to let you know to change the batteries. I ve pushed my aw inr s to the point that the light stays in lockout and won't turn on. They read 0% when I put them in the VP 4 Dragon charger but so far no problems or short life. I m actually using the Tomahawk and TMax more than the HDS lights.
