ergotelis
Hi, less than 2 days from shipping time i received my order(thanks dhl!) .
It was for a local group buy, 15 DQG II R5 + 2 DQG II R4.
Package had only flashlights plus some o-rings, no packaging, something like bulk sale. No problem for that!
So, how do i find this new flashlight?
With one word, amazing!It is the smallest AAA flashlight i think!
Some characteristics:
Using CREE XP-G R5 / R4 LED
Material: 304 SS
Switch: Head twist on/off
Two modes of brightness: Lo>Hi ;
Rotate head to change modes;
Current drawn: Lo 25mA>Hi 210mA (scroll down this page, i measured current on the battery and the 25ma mentioned here look quite high, so the runtime mentioned here will be a lot higher)
Runtime: 60mins on hi; 10hrs on lo, with quality AAA
Using PMMA diffuse lens, Angle:15 degree
Luminous O ring on the head
Battery: AAA
Anti-reverse protection
Ashproof and waterproof
Weight: 12g
Some construction notes:
Build quality is very good due to Stainless steel.
The flashlight has GITD o-ring under the optical lens and on the tailcap, a magnet or a GITD disk. The magnet, is quite useful, especially for camping. Though, the magnet is not so strong, in some metal surfaces, which are vertical, mounted with an eneloop, the flashlight might not sustain its position. But in most cases, where there won't be a lot of vibrations, you won't have a problem with the magnet, it will work fine.
The GITD disk is quite nice, glows a lot if charged and sustains its light for enough time!!
There are no springs, the flashlight lights up when you tighten it up. Do not try to put a spring, is will be simply always powered on. The battery rattles when it is off, but all these are done in order to reduce to the minimum its dimensions. Threads are quite nice, no problem, lighting it up is quite smooth.
There is some quite good knurling both on the body and the head which let you operate it with one hand.
As for its weight, in fact, it doesn't weight. Only if you put an eneloop you can understand that there is a little bit of weight.
The led might not be always centered, but not up to a bad point and the optical lens is quite nice.
It can tailstand.
Some performance notes:
The flashlight is drawing 0,55-0,6 amp, so i guess it will be giving at least a good runtime on high. On low, i measured 0,03-0,02 amp, so you might get up to 1,5 days of good runtime continuously.
There is no clear performance loss in the R4 edition over the R5 edition. At least on mines, could not measure noticeable difference. I estimated its output, at least on startup, over 60 OTF.
Do not use lion batteries, you might burn it. The design of the flashlight protects from reverse polarity, so don't worry on that!
Someone might notice a bit of greenish tint in some flashlight, R5's have different tint among them. THe R4's are really neutral, not very yellowish, something like sunlight.
The beam is very nice, nice big hotspot with a less bright corona, perfect for edc.
Here is a comparison pic:
If you want to see a lot more photos and beamshots visit this page:
http://www.avclub.gr/forum/showthread.php?t=80788
It is in Greek though, but i can answer all you questions.
IF you want outdoor beamshots, please wait a few days.
I can compare it with some other famous edc's:
Zebralight sc60
Zebralight sc50
ITP A3 eos S2 AAA ti edition
4sevens mini123 S3 edition ti
4sevens miniAA
4sevens miniAA2
itp A2 eos AA SS
fenix p1d ce(remember this?)
Material: 304 SS
Battery: AAA
Weight: 12g
It can tailstand.
Zebralight sc60
Zebralight sc50
4sevens miniAA
4sevens miniAA2
itp A2 eos AA SS
