Fix a stiff EZ123 fast n cheap
Beamhead
gone "Squatchin" :p
I found these at my local wallyworld, you get 9 for 97 cents and they work great.
First carefully remove the original foam ring. Then stick it to the self adhesive side of the corn pad lining up the holes and trim.
Then stick it to the head.
This makes operation easy and still provides padding to prevent battery rattle. You can even put the corn pad on the bottom of the cell being sure to center it just right for single mode high only use.
Seen here on an EZAA.
Yes this is a very good solution. I've been using that exact product for years on a few lights that need it - still have some left as one package will do a lot of lights :thumbsup:
I don't own one, but a good tip is always appreciated.
:twothumbs
