I have manage to break a Terralux TLE-6EXB (in a Maglite) by dropping it 3 - 4' onto the concrete. It is too old (~2 years) for a warranty claim according to Terralux.
The symptoms are: when turning on the light, the LED will flash briefly and go out. If I turn the switch off and back on - another single flash. Sometimes the light will stay on for several seconds - then it goes out, the back to a single flash. Pretty sure it is not the flashlight - cleaned the contacts and the regular bulb works fine.
Is there anything that could be fixed on the LED?
Did I just have bad luck and replace it with the same (I really liked the light and battery life)?
Or did I learn a lesson should replace it with (fill-in the blank)?
Thanks!!!
Thanks!!!
