hoongern
Hi guys,
I'm not sure if this should be in the general forum, battery forum, or incan forum.
So JUST 2 hours ago I opened up my package with brand new AW IMR18500 Lithium Ion batteries, and couldn't resist doing beamshots. So I was out doing beamshots, and I decided to change from the LF IMR-9 module over to the FM D26 T1.5 socket. I left the batteries inside while changing it.
When I tried to turn on the light (Using the twisty switch) - I noticed the light flickered and died. At first I thought it was just the contact, or at worst, the bulb going
. Then a second or so later, I realized that the body of the flashlight got pretty hot. So I opened it up.... Sighhhhhhhhhhh...
There goes a huge amount of $$ down the drain in a couple seconds.
Now my question is -
What did I do wrong? Are you supposed to remove batteries when changing D26 modules? All parts were working fine, so it's definitely not FiveMega's, LumensFactory's, or AW's fault. But I just did what I'm used to, just swap in a different module. And I didn't notice any problems until I tried to power it up. Of course, there must have been some short circuit somewhere.
I'm gonna have to write off these BRAND NEW batteries, sigh, get a new tailcap, get a new D26 module, unless I can acquire just the springs.
Also, it didn't smell good. Should I be worried about any chemicals?
Regardless, let this serve as a warning to all about the awesome power of IMR cells, and high powered incans. Definitely not the nicest thing to experience. Thank God IMR cells are safe chemistries.
