hello CPF people! did i post under the right category?
well ive been around here before but ive been holding off registration because of age restriction in old "terms of use" thing..... me being 16 and afraid of being banned from places.... well apparently it seems to have been changed and i am here and excited to learn to build a better torch....
im pretty adept in computers and overclocking so i know about cooling and the different interface materials and so on.
i also know a good deal about electronics.... enough to build boards from schematics if needed... or if its cheaper to make.
ok to what i wanted to know about, i have myself two flashlights, a maglite 3D light and this ripoff 3D flashlight called "snap-on xenon flashlight" its anodized red and not even on the manufacturers site.....got it from costco if you understand what im talking about.. obviously not xenon as the bulbs are not even as intense as the krypton ones in the mag... reflectors melted too...
i also plan on getting a 6D mag just to have one, always wanted a flashlight big enough to double as a club and excel at that. ill eventually mod that too.
alright, so i want to make a flashlight, both the mag and snap-on have identical parts, similar size, inner diameter, they basically can use the same lenses, reflectors, springs and screw heads and stuff... there is only very few changes between them, but those are what matter and the reason i wanna mod them.
i wanna use SSC P7 C bin LEDs, 3 if i can, ive been browsing kaidomain and dealextreme for stuff and came across a few things.
http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=3960
would a P7 fit into this 3 LED reflector if i used a stepper to widen the holes a couple mm?
is an aspherical lens good? is it worth the cost?
http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=4167
does a lens like this color light in any way, are they good?
http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=4304
will the above lenses break easily if i try and smash the lights into someones head?
how big is this driver? they good? can it fit inside the mag body easily? how about a minimag?
http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=4338
are Li-ions worth it? what should i know about them? are they much better than something like NI-MH batteries like eneloops? is this below battery good? how long does it hold a charge?
http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=3985
thanks guys, hope to get started on this project soon and annoy my neighbors and friends!:devil:
EDIT: yup i think i posted in the wrong place.....
