- Joined
- Jul 15, 2021
- Messages
- 54
The flexible LED Sheet lights have numerous LEDs mounted on a large dual-layer PCB board to make them highly flexible and allow them to be bent, shaped, and cut for various applications: countertop backlighting, lighting boxes, advertisement displays, signs, and other DIY works, etc.
Link: LED Sheet Lights
Material: Dual-layer PCB boards and high-quality SMD LEDs to ensure they can withstand bending and shaping without damage and work longer.
Lighting: The panel lights mainly use 2835 or 5050 SMD LEDs as the light source; the high-density LEDs make them create evenly lighting without dark areas and light spots.
Working Voltage: They are working on DC24V. It's easy to connect to a power supply to light up directly or connect to an LED controller to adjust the brightness, set dynamic modes, or various colors.
Color Options: Except for the various single colors, dual white, RGB, RGBW, and RGB+CCT are available.
Cuttable: You can trim the LED sheet lighting to various sizes or shapes following the supplied cut lines in either direction.
Connectable: They have connectors, so you can easily link many together for your projects without soldering.
Installation: The back has double-sided adhesive tape, so removing the protector paper and sticking it to where you want to install it is easy.
Applications: They can be used as backlighting for countertops, cove lighting, accent lighting, etc., in residential and commercial settings.
