"Flydragon" sst-90 monster with big aspherical lens
I pre-ordered it 😗😗😗
Will post a review when it gets here 3-5 weeks lead time!
My stepfather lives on like 10th floor looking over i-95, hopefully it won't blind anyone....
Anybody get the CSM 360 yet??? I needs more pictures!!!!!!!!!!!!!!!!!!!
I may be first out of Asia to get it. But lead time was 3-5 weeks, so I would not expect it before early october.
It will come in handy when I can't find a light switch!
2D80 is priced more than US$400ish (after pre-order offer) which is more expensive than SR90 and it does not even come with batteries. Add another 6 pieces of unprotected 18650 which is going to cost you another $60-70. Not really worth it in my opinion.
*Highlights (2D80 improvements in the new edition)
• Bezel with adjustable focus (optional)
• High performance, long distance searchlight (compatible with D80 adjustable focus bezel). 25mm adjustment range, beam angle adjustable from 1-120 degrees. (At a distance of 10 meters, the hotspot size is adjustable from 10cm to 20 meters)
what you think? are zooming flood to throw or not?
with an adjustable head, you are essentially changing the focus from diffused to tight, this does affect the beam pattern, it's not going to be a pure flood without a hot spot if that is what you are asking but the adjustable head will have the effect similar to flood.
I love aspherics and could possibly get one of these. But a light using multiple Li ions is a dangerous proposition. I would never run a light with 6 18650's. That's an explosion waiting to happen. Even if they are 6 AW's.
It is doable, but you've got to run the light for a few minutes and remove the batteries to see if any are getting hot then increase the time and check again. Those batteries should stay matched in that light and I might even drill a small hole in the light for venting.
i have not seen this light except on photo, but based on the diagram above, it looks like the head will extend from the flood position to become fully focused, so my guess would be a sliding sytem possibly with twisting to help fine tune the focus.
I call BS
We have been waiting soooo long for a light of this magnitude to have flood to throw capability.... it just can't be..... nope....... I don't care what anybody say's, I don't believe it.......... but can it be?????...... Na...... :sssh:........:shrug:
Sorry to Stick my big mouth in here..
its awhile since i was looking at new stuff around here.
I have one of the Mag with the KD cree drop in and aspheric kits and also a tiablo with aspheric.
it seems that there are bigger and better out there now..this looks like what ive been looking for all the time.
is there any kits out there that can change the aspheric on my mag to a larger aspheric.?
or any that are for sale with the big apsheric ?
cheers
vin
cheers
vin
you can mod it but not are easy (many grind work)
http://www.candlepowerforums.com/vb/showthread.php?t=280670
the production is coming along, you'll have to wait for someone to receive one and post their own videos. I believe currently there are only 2 ordered fom the US, and one of those 2 won't be shipped till late oct. by request.
