Sold/Expired FM-D26 Bi-Pin socket/Reflector Ready to ship
fivemega
California
(CLOSED) FM-D26 Bi-Pin socket/Reflector
(C L O S E D)
NOT AVAILABLE
Hi Folks, please read this entire post before ordering
Here is another creation from FIVEMEGA.
A bi-pin socket/reflector that can be used instead of D26 lamp assembly in $urefire flashlights. (may not work with other brand flashlights such as Superfire or Ultrafire.)
No more $25-$30 lamp assembly poof.
Simply insert a bi pin bulb of your choice into the socket, install the bi pin socket in reflector, focus it the way you prefer, lock the set screw GENTLY and ready to use.
Possibilities:
Strion bulb to use with single li-ion 17670 in $urefire 6P
Scorpion bulb to use with 2x123 primaries in $urefire 6P
TL-3 bulb to use with 2 li-ion cells or 3x123 primaries in $urefire 9P (LOLA)
CL1499 bulb to use with 2 li-ion cells or 3x123 primaries in $urefire 9P (HOLA)
FM1794 bulb to use with 2 li-ion cells (1500mAh+) in $urefire 9P (XHOLA) AVAILABLE HERE.
FM1794 is an extreme high output halogen bulb (brighter than P91) which is special order and made exclusively for FIVEMEGA (7 volt, 3A, 50MSCP, 3400K, 10 HRS life) AVAILABLE here.
22 Watt axial bulb to use with 3 li-ion cells in $urefire 9P with extension. AVAILABLE HERE.
There are many other T-1.5 bulbs to use with this socket/reflector in different battery configuration.
Advantages:
Low cost bulb. ($6 for Strion or TL-3 / $9 for CL1499 or $? for 1794[/color]
Many possiblity and choice.
Easily convertible from 3.7 volt to 7.2 and....
Choice of different textured reflector from throw to flood. (VLOP, MOP, LS and HS)
Choice of getting different textured extra reflector. (As many as you want)
Focusable as you wish.
And since the bulb is removeable, you can also frost it half way down, 2/3 or entierly for excellent soft quality beam.
Each socket comes with allen wrench for GENTLY secure set screw and lock inside reflector.
Each reflector can carry two small extra bulbs as spare so you never left at dark. Do not use for 1499 and 1794 bulbs. (See TL-3 spare bulb at left second picture).
You can find variety of black HAIII bodies in several sizes (C head/C tail) available here. These bodies can accept 18mm diameter cells and are necessary to use with high wattage bulbs such as 1794 or P91
Need even more capacity and run time? This is the solution.
Exact match and excellent result when combined with these heads.
Price:
$26 for socket/reflector (NOT AVAILABLE)
$14 each extra reflector (NOT AVAILABLE)
$14 each extra socket. (NOT AVAILABLE)
$6 Strion bulb (NOT AVAILABLE)
$6 TL-3 bulb (NOT AVAILABLE)
$9 CL1499 bulb (NOT AVAILABLE)
$5 shipping to States (any quantity)
$8 internationaly (any quantity)
It is necessary to post detail of your order here and paypal note including your CPF ID handle.
I will never figure out what payment is for and from whom without above information.
Example:
CPF handle: JackB
:paypal: for
One socket reflector (MOP) $26
One extra reflector (HS) $14
Four FM1499 $36
Shipping $5 to States
Please PM for alternative payment method. (Postal Money Order)
Free shipping when paid by USPS money order.
Paypal: DO NOT PAY
Please note: I am not manufacturer of any bulb and don't sell them for profit. I offer them here only for your convenience to get them all in same shipment therefore NO WARRANTY on any bulb. If you are not comfortable with this, please get the bulbs from elsewhere.
(NOT AVAILABLE)
(C L O S E D)
PhotonAddict
Mtl, Canada
FM, in your opinion which reflector would be closest to the reflector on a Streamlight TL-3 with regards to the beam produced?
Jay T
:paypal:by Jay T
For
1 Socket reflector (vlop) $26
3 x 1499 $27
3 x FM1794 $20
a 2x18650 body $48
Shippin $5
DM51
Borg cube #51
Paypal sent for:
1x black 2x18500 body … $45
2x black 2x18650 body @ $48 = $96
4x FM-D26 socket/reflector (VLOP) @ $26 = $104
2x FM-D26 extra reflector (MOP) @ $14 = $28
6x Strion bulbs @ $6 = $36
4x CL1499 bulbs @ $9 = $36
4x FM1794 bulbs @ $10 = $40
Intl shipping … $8
Total … $393
Thanks!
softfeel
Sweden
CPF softfeel :paypal: for:
$26 for socket/reflector (VLOP)
- $14 extra MOP reflector (MOP)
- $9 CL1499 bulb
- $30, 3 x $10 FM1794 bulb
- $8 internationaly
$87 total
gswitter
California
PayPal sent for:
  • HA black 2x18650 body: $48
  • HA black 2x18500 body: $45
  • FM-D26 socket/reflector (VLOP): $26
  • FM-D26 socket/reflector (MOP): $26
  • FM-D26 extra reflector (LS): $14
  • FM-D26 extra reflector (HS): $14
  • shipping to States: $5
Total: $178
rdh226
Nashua, NH, USA
WooHoo!
And they hold two -- count'em TWO -- spare bulbs! Take that, Mag-Lite!
He he
I'll take:
$048 (1) x 2x18650 black body
$104 (4) x Socket/Reflector (HS)
$052 (2) x Socket/Reflector (LS)
$028 (2) x Reflector (MOP)
$024 (4) x Strion bulb
$024 (4) x TL-3 bulb
$072 (8) x CL1499 bulb
$080 (8) x FM1794 bulb
$030 (3) x Axial 11Wt bulb
$005 (1) S&H
$467 Total
-RDH
Edit: PayPal sent.
donn_
Great South Bay, LINY
:paypal:
1x socket/reflector(VLOP)
1x socket/reflector(MOP)
1x socket/reflector(LS)
1x socket/reflector(HS)
2x extra reflector(VLOP)
3x CL1499 bulb
3x FM1794 bulb
2x Axial 11 volt bulb
Please combine with 3x18500 Black order.
:thanks:
PhotonAddict
Mtl, Canada
FM, Paypal sent for:
- 1x HA black 2x18650 body: $48
- 1x HA black 2x18500 body: $45
- 1x FM-D26 socket/reflector (LS): $26
- 1x FM-D26 socket/reflector (MOP): $26
- 1x FM-D26 extra reflector (HS): $14
- 1x Strion bulb: $6
- 1x TL3 bulb: $6
- 1x CL1499 bulb: $9
+ International shipping: $8
Total: $188
Thanks!
yankeefist
:paypal:for:
1x socket/reflector(MOP) $26
1x socket/reflector(HS) $26
2x fm1764 bulb $ 20
4x strion bulb $24
shipping $5
$101 total
sieck77
singapore
Hi FM,
:paypal: by sieck77 for the following items.
Item List:
1: $26 for socket/reflector(VLOP)
2: $14 for extra reflector(HS)
3: $10x3 for 3pcs FM1794 bulb
4: $8 for international shipping
$78 Total
habibi
Germany
Hi FM!
I am in with:
1 x FM D 26 socket/reflector vlop
2 x CL 1499
Paypal sent!
Cheers from Germany
CancerLad
Paypal sent for
Two CL1499 bulbs, $9.00 x 2 = $18.00
Two FM1794 bulbs, $10.00 x 2 = $20.00
Shipping to States, $5.00
4 % PP CC fee ~ $1.75
total $44.75
Thanks.
TKO
[SIZE=+1]VLOP, MOP, LS and HS?
MOP = Medium Orange Peel
What are other three?
Does VLOP = Very Light Orange Peel?
My P91 has a pretty aggressively stippled surface. Would this equate to MOP?
[/SIZE]
