Phaserburn
Anyone using this in an all Solarforce L2 2x18650 setup? Curious as to the fit.
Any chance of an identical D36 product?
anyone? I'd really like to order...
Simply insert a bi pin bulb of your choice into the socket, install the bi pin socket in reflector, focus it the way you prefer, lock the set screw GENTLY and ready to use.
Possibilities:
FM1794 bulb to use with 2 li-ion cells (1500mAh+) in $urefire 9P (XHOLA) AVAILABLE HERE.
FM1794 is an extreme high output halogen bulb (brighter than P91) which is special order and made exclusively for FIVEMEGA (7 volt, 3A, 50MSCP, 3400K, 10 HRS life)
22 Watt axial bulb to use with 3 li-ion cells in $urefire 9P with extension. AVAILABLE HERE.
Got my order, thank you very much, FM, you rock! :rock:
So now I can use Strion, Scorpion, TL-3, CL1499 and FM1794 bulbs in my P60/D26 sized Surefire heads; any other good 1.5mm bulb options?
(the link on that on page 1 of this thread has gone cold)
lovecpf
Your other thread has the 1794 bulbs available.... can I combine the sales from two of your threads and order the socket/reflector and the 1794 together in one order/payment?
HS Reflector w/ socket...... $26
(2) IMR-16340.................. $12
(2) CL1794 bulbs........... $30
Shipping........................... $5
Total................................. $73
Please advise,,,, thank you.
