My2Cents
Long time viewer, lots of useful information, thank you.
Now it's time for me to put in my 2 cents.
I'm using hobby charger to test capacity of LSD size C used for my kid's toys.
First, using MH-C808M, I did a soft charge and condition on 4 of each.
Then each battery will go thru 4 discharge/charge cycle on BC6DX-II.
There is a 60 minute pause between discharge and charge.
Each set takes about 4 days so I will post next set as it becomes available.
Also, I'm a consumer and not affiliated to any of the products here.
AccuEvolution 4500 mAh (purchased Mar 2011)
Charge .5 amp (.1C rounded up) until 1.6C (7200mAh)
Discharge .9 amp (.2C) until .9 volts
Immedion C 5000mAh (purchased Jan 2011)
Charge .5 amp (.1C) until 1.6C (8000mAh)
Discharge 1 amp (.2C) until .9 volts
A picture is worth a thousand words, so here we go.
For set 'A' it's 90 seconds charge, then 6 seconds pause (no charge), repeat.
Discharge mode is constant current.
AccuEvolution C MAR.2011.A cycle.
AccuEvolution C MAR.2011.A 1 amp discharge to .9 volts using EOS0720i (4670 mAh).
Imedion C JAN.2011.A cycle
Imedion C JAN.2011.A 1 amp discharge to .9 volts using EOS0720i (4525 mAh).
