There is a formula for calculating the beam angle of lights -
α = 2arcCos ( 1 - Lm ÷ ( 2πCd ))
where Lm = maximum light lumens
Cd = maximum light candela
This formula applies ONLY for light beam angle where the beam intensity (candela) has fallen off to 50% of the maximum candela intensity.
But, there is another light beam angle known as the "field angle" which is a bit wider than the main light beam angle. This field angle occurs when the beam intensity has fallen off to 10% of the maximum candela intensity.
As far as I'm aware, there doesn't appear to be a formula to calculate the field beam angle? At least I haven't as yet found such a formula by searching the web!?
So, is there a formula for calculating the field angle of light beam? If so, what is it please?
