Glenn7
@ KITROBASKIN - that QT 18650 is just photoshopped in without beam shots
As good as it gets: Hard User tweaked the beam cast before deciding to sell it to me.@ KITROBASKIN - that QT 18650 is just photoshopped in without beam shots![]()
Pop out the holder for the capsule and reseat the capsule on the magnet and then pop the holder back in, it should be back to normal. This happens to me if I twist too far. The capsule will continue working fine after reseating in my experience. Don’t even need to flip it over just give it a wiggle or a slight turn.I'm getting hour an a half runtime each evening for a project. Think I've work out the regulating material... light flickers for no reason and doesn't get beyond ~300 lumens.
Exactly, or even wide tweezers. It can be done with fingers but it’s a pain! The small brass cube pops out, the capsule is a small black disc of rubber that’s held in place by a magnet. I just wiggle that black rubber a bit and slot the brass block back into place after. Make sure to note which side of the brass block has the deeper Groove and put it back the same way, or just be ok with breaking in the other side too.It’s very simple. Just tap the body upside down on the table. The QTC/holder will fall right out then if you want you can remove the QTC pill and put it back on. I never do. Then using pliers put the QTC holder back on. That’s it.
Take the QTC pill out and see if it gets hot. That’s supposed to be full power.I rotated 90 degrees.
Worth noting that the light doesn't get hot anymore when running wide open.
