ecmp,
A tail switch is not in keeping with the nature of this flashlight, though a talented individual could modify one. Its simplicity of function and use took may iterations in order to fulfill the design goal.
The 26650 Lumenite ll has a 20mm board according to the website. The others are described in the thread here on CPF. Hopefully someone will come forward with that information.
The website also describes the optics used for the different models.
Emitters are listed, for which one can research. Given that there are no changes to the battery output other than connectionst/material circuit resistance, consider that batteries give whatever the path allows; maybe someone has measured it?
The body lip makes contact with the brass(?) piston. A well used sample will show contact wear. It is maybe two thirds of a rotation? Plenty of room for adjustment.
The weight of the 18650 QT-L is more than the usual aluminum compact single emitter 18650 flashlight, but feels fine; maybe a similar weight to a high end flashlight. Its length is very close to a similar side switch.
The Lumenite ll is pretty beefy and a little longer than the QT-L. If you haven’t already, take a look at images I posted second page December 20th showing them on a balance beam in the thread
www.candlepowerforums.com
State of the art, today?
For me, the most radical lighting technology advancement lately would be LEP, Laser Excited Phosphor. Considering the time that Muyshondt was considered the latest and greatest, probably the best thrower out there was saabluster's DEFT lights. Now, these LEPs have nearly twice the CD and in a...
