Other's more knowledgeable will chime in but the buck driver is the limiter, the battery pack will shut down at it's limit both with overcharge and at the lower limit, and constant current isn't necessary but is used if your want ...constant current...constant brightness throughout the burn time rather than a longer burn time at decreasing brightness.
Maybe I'm just stating the obvious and haven't completely understood your question!
The buck driver is a voltage limiter, the issue with the SST-90 is that it can draw >10 A (which is above spec) even at lower voltages. So the watts=heat=thermal shutdown and/or burn out.
So it's not enough to limit the voltage, amp limiting is required as well.... least thats my layman understanding.
I look at this PCB and read that it limits to 10 A... still above spec but well below the 12-13A the LED has be shown to draw.
Is this a good short term solution while we wait for a more "traditional" driver?
With Canister based lights we have the advantage of additional space and PCBs ;-)
