Frozen alkies
Mrdi
CA
Not Drunks.
Does it actually help the longevity of alkaline batts to store them in the freezer ?
Try it out and let us know.
By conventional thinking, heat will speed up chemical reactions, so reducing the temperature of the reaction will also reduce the reaction speed.
But consider if you freeze the batteries, that whatever liquid there is inside might crystalise (though there is usually very little and all that usually in the form of a gel or paste). That is generally very bad news for seals which means your batteries will probably leak once you take them out. Of course, there is the possibility that the liquid freezing point is below that of your freezer, so you're safe.
