Sold/Expired FS: Aurora V6 XPG programmable
Zefiryn
KRK PL
For sale modded Aurora V6:
- selected low fV XPG R5 emitter
- bin XPGWHT-L1-0000-00H53 tint 00H53 (5000 - 7000K)
- OP reflector
- Programmable driver
- best as EDC or bike light ;)
Driver functions:
* 7135 AMC linear driver
* voltage range 2.8-6V (best to use 18650 battery)
* 3 mode Driver -modes can be changed by 1 or 2 clicks (configurable)
* Memory mode can be turn on/off
* Brightness settings: adjustment from 0.4 to 100%
- super-low mode (0.4% brightness )
- digital control of Fast-PWM
- brightness settings on/off (configurable)
* No Flickering effect
* Automatic voltage control ( configurable):
- low battery voltage Warning (<3.05 V)
- moon-mode: power saving mode with reduced brightness (<2.9 V)
- discharge protection (<2.8 V)
* optional configurable strobe mode, can be switched on/off
If turned on, strobe mode available as a 4th mode
Control :
* Mode change: 1 or 2 clicks (configurable)
* Brightness : 3 clicks - enters mode brightness settings (ramping from 0.4-100%) single click memorise desired level
* Driver configuration : 5 clicks - enters driver configuration mode:
1-click at high or low light selecting Yes/on (high), no/off (low)
+ Strobe mode on/off
+ 1 or 2 clicks mode change (yes/no)
+ Voltage control on/off
+ Memory on/off
+ Brightness settings on/off (if off then brightness regulation disabled)
canceling changes and exiting configuration mode automatically after 6 full cycles with no change
2 pcs available with 3xAMC1050mA driver
$ 59 shipped, please add 4% for paypal fees
This post is defintely in the wrong spot - it should be over in CPF Marketplace, probably Dealers Corner....
gg
Thanx, I'm not a manufacturer and don't intend to be , for now only couple of pcs home modded, ;)
At the moment I don't need one but I'll contact you when I do my next build ... The driver has a new UI right (new programm on the µController)? There was a similar project in a german forum. thanks
