kz1000s1
Selling a Cree MC-E powered Energizer 1xAA light.
The original Cree XR-C led has been replaced by a WF color bin Cree MC-E.
The MC-E is mounted on a copper plate in place of the original star. It's
running through the original regulator and I've been tested one of these
lights for months with no problems. You can run it off of a LifePo4 3.2V AA
battery from Walmart, or a 3.7V 14500 Li-ion (no battery included). My
meter says 1 amp draw on the 14500, but I'm not sure that is accurate.
The positive contact on the board has a solder blob added so the light will
work with older flat top 14500 cells like the AW"s. This does however disable
the polarity protection, so be careful not to insert a battery backwards.
The beam is very smooth with the textured reflector. A large hot spot
with a lot of flood, but it still has a little throw. Although there is no X
in the hotspot, a small dark hole is in the middle. It isn't very noticable
in normal use.
If you hate the sensitive switch on these lights, It has been modded to
increase the momentary switch travel and the button pressure. Now it feels
more like a Surefire Z57 clicky. More info on this mod for your switches.
http://www.candlepowerforums.com/vb/showthread.php?p=2944850#post2944850
Built on a new light. Comes in the original blister pack with pocket
clip and lanyard.
$65 $60 SOLD USD shipped CONUS.
Paypal ( CC Ok ) or USPS Money Order.
in normal use.
clip and lanyard.
