Sold/Expired FS: FM 18350 P60 (3P), Maglite MTG2, T-Mack Copper
light-modder
Kansas
Alright well I have decided to put some of my flashlights up for sale. This is my first sales thread so we'll see how it goes.
Blue 2D Maglite I got a heatsink and reflector from Jayrob for this build. It's the 4000K MTG2 bonded to the heatsink with AA and the driver cavity was filled with it as well. It's a great light but I'm trying to get a grail light so some things have to go. It is driven by a 4.5 amp qlite driver. It has three modes. An important side note, I wasn't thinking clearly when doing this build and when I soldered the wires on the driver I thought the 20ga wire was kinda small so I doubled up on it. There are two positive and two negative wires on both the switch and driver. To make things better I didn't use shrink wrap because I didn't think I would ever try to sell the light. I did wrap each joint in electrical tape though. A plus to all this is that with all that wire the resistance between the switch and driver is quite low and I did measure 4.5 amps at the led with my cheapo meter. Ok so these aren't the best pics I didn't realize I didn't have any good ones of the light itself. It is used so it does have ano missing, mostly at the back end I will get some pics and upload them.
$125
Next up is a red Convoy S2+ with a triple xpl hi v2 1a 6500-7000K, has a copper spacer under the star, a narrow spot optic, I have a deep carry clip that will go with it I have not installed the clip but it does come with the flashlight. I put a thermal cube in the driver cavity. I used the blf a6 driver on this one. It's a FET+7135 driver there are a lot of features on this driver: I have copied this from someone else but here they are,
- Short tap: Do a short (less than 0.5s) half-press to go forward to
the next mode.
- Med tap: Do a medium (0.5s to 1.5s) half-press to go backward to
the previous mode.
- Long tap: Do a long (longer than 1.5s) half-press to reset to the
first mode (if mode memory is turned off).
- Or fully click and release to turn the light off.
Hidden modes:
- Go backward from moon to access the hidden modes. They are, in
order:
- Turbo (just like the regular turbo)
- Tactical strobe (10 Hz)
- Battery check / beacon mode
(each blink represents about 25% of a full charge)
0 blinks: < 1% full (< 3.0V)
1 blink : 1% to 25% full (3.0V to 3.5V)
2 blinks: 25% to 50% full (3.5V to 3.8V)
3 blinks: 50% to 75% full (3.8V to 4.0V)
4 blinks: 75% to 100% full (4.0V to 4.2V)
5 blinks: > 100% full (> 4.2V)
- Biking flasher (2-level stutter beacon, 1 Hz)
Configuration options:
- Short tap rapidly a bunch of times (15+ taps, or until the light
stops turning on) to enter soft config mode.
The way it works is the light will blink twice for each option,
then pause for a bit before moving to the next option. Turn the
light off between the two blinks to toggle that option.
The available options are:
- Mode group: 7 modes or 4 modes:
Group 1: moon, low, med1, med2, high1, high2, turbo
Group 2: low, med, high, turbo
- Mode memory toggle
- If CONFIG_STARS is defined, you can ground pin 3 of the MCU to
enable mode memory instead of using config mode. This can often
be done by soldering a star on the spring side of the driver, if
your driver supports that. Otherwise, it's pretty easy to make a
solder bridge from pin 3 (mode mem toggle) to pin 4 (ground). Or
even just wedge a piece of metal between the two pins.
Other details to note:
- Low-voltage protection will progressively step down the output at
about 2.8V, and the light will shut itself off when even the
lowest level gets below 2.8V.
- The default turbo step-down is 45 seconds.
- When turbo steps down to high, a short tap will push it back up to
turbo or a medium tap will step down further, even if you got to
turbo by going backward from moon. The step-down effectively
moves it from the "hidden" turbo back to the non-hidden turbo.
- A short tap from any hidden mode will return to the lowest mode.
$100 for this one.
I can't post anymore pics in this post and can't figure out how to delete some of the other ones so that I can post new ones. I will post pictures further down the thread.
Conditions of sale are: first "I'll take it" posted in this thread gets it. Shipping to US address included, PM me about international shipping.
Thanks for looking.
light-modder
Kansas
FortyCaliber I was going to give anongpc a couple more days as we have exchanged a couple pms.
Mcbrat thanks for the link. I haven't gotten any of my pics put up yet. Looks pretty good on my desk though.
anongpc
hi,I have paid for 3p already...when you shipping out please sent me tracking number--:nana:
light-modder
Kansas
I apologize anongpc, I was going to ship today however they did not open till 10 and I had to be at a service project at 9. I didn't realize they open later on Saturday, I figured they'd close early but opening later is kinda silly. I'll ship it Monday.
light-modder
Kansas
Pictures of 6P
Forgot to mention that the smoothie bezel looks brand new, has a UCL held in with just a plastic bezel ring. Lens is ar coated. The tail cap is a definite user but the body is also in very good condition with I think maybe a little spot of aluminum showing through on the knurling.
