Sold/Expired FS: Jade 3D Mag80 **Withdrawn**
DMC
Austin
**Withdrawn**
Cheaper Jade Mag85 configuration coming soon!
For Sale: Jade 3D Mag80 for $160 includes CONUS/Canada shipping.
- Tungsram GY6.35 6V 35W 56580 axial filament
(Osram 64430) bulb http://www.svetila.com/eProdaja/product_info.php/cPath/91/products_id/4058
First "I'll Take It" with a follow up PM to me for shipping and PayPal details.
What's included:
Less common
Jade 3D Mag!
Kui's high temp D cell socket switch
2 extra Tungsram 56580 bulbs
FM's MOP 12.7 Reflector
FM's 9AA3D battery adapter
9 NIMH Intellect IB2000 high drain batteries http://candlepowerforums.com/vb/showthread.php?t=151898
Borofloat Lens
1 Dummy AA
Re: FS: Jade 3D Mag80 /w Soft Start Switch
I,
I'd like to know if you have ever tryed to run the tungsram bulb with 9 cells??
fron the LuxLuthor test seems that this bulb can support a ot of voltage...
thank you and good luck with your sale!
Yes, but it is a great way to pop at 56580.
You need to make sure the the battery voltage is 11V or less.
See Lux's Destructive Incan Bulb Tests http://i61.photobucket.com/albums/h75/pike444/bulbs/56580Tungsram.jpg
Even 8 batteries hot off the charge is 1.4V*8 = 11.2V and could flash a 56580. But 9 batteries hot off the charger 1.4V*9 = 12.6V and will flash a 56580.
I think someone may be interested.
I have just tryed to run the tungsram with 9 elites 1700 with an NTC and not instaflash...
so with DMC package and a soft-starter you can get more lumens.;) (batteries must be rested... best under 12V)
FILIPPO,
I just swapped out the AW soft-start switch with a Kui switch and dropped the price from $210 to $160. If you all want the AW soft-starter switch instead of the Kui switch then the price is still $210. I will update my posting with this info.
Stansbrew,
Here is the FM's posting for these battery holders
http://www.candlepowerforums.com/vb/showthread.php?t=182370
with the recommended battery charger from BatterySpace.
Here is the particular BatterySpace charger I use
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3331
The nice thing about this charger is that you can modify the alligator clips to use FM's plug. No need for magnets and I don't need to remove the battery holder to charge the batteries.
Sold the AW Soft-Start switch to scottaw.
