jimjones3630
Below with borofloat lens,
fresh charged Emoli cells.
Got throw? Below is over 100 yds. to front gate
Aspherical lens makes it easy.
NTC cures instant flash with Phillips 5761 & 2 Emoli cells.
http://www.candlepowerforums.com/vb/showthread.php?t=177344
Aspherical lens for incandescents.
http://www.candlepowerforums.com/vb/showthread.php?t=179681
Review by Northern Lights post #36
http://www.candlepowerforums.com/vb/showthread.php?t=179681&page=2
Comes with one used Philips 5761 bulb, over 1300 bLumens, beat 1185 with less volts.
WA1160 great LOLA bulb with supplied NTC mod. Steps down votage to 6.9vbulb giving
over 1,000 lumens noted on Hot Rater.
Tail cap spring mod with NTC controlled surge protection soft start,
Amertherm SL12 1R010 NTC, end of instantflashes.
Ceramic blanket insulation for 5.5A of 5761 bulb
Mag 3 C-cell flashlight, black color. Or 2D red or silver your choice.
2 Emoli cells.
Low resistance switch fit, bi-pin direct wired to switch,
more volts to bulb = brighter run time.
2 Emoli cells.
Aspherical lens increased throw and have usable side spill,
BK7 glass with higher heat resistance than Borofloat or UCL windows
SMO non camed Carley reflector
Unlike Lithium Polymer batteries, these cells are very rugged.
It is encased in a steel can similar to NiCAD/NiMH batteries.
Specs:
Dimension: 26mm diameter x 70mm length
Weight: Approximately 100g
Mfg Claimed Capacity: 2670mah
Nominal Voltage: 3.7 V
Charge Voltage: 4.2 V
Mfg's Max Continuous Discharge Rate: 20A
Max Tested Continuous Discharge Rate* 45A (15C)
* Not endorsed by Manufacturer.
One Aspherical Lens, 3CM@g61, or 2DM@g red or silver your choice , 2 Emoli cells, 2 5761 bulbs, NTC moded tailcap, shipping CONUS and paypal fees included all for $190
Optional AW ver. 1 driver with AW fix. $75. Starter Li battery charger $30
