FS: Malkoff MDC 18650 to E-Series Body / Vinhnguyen54 modded lights *Price Drop 10/25*
Wurkkos
moshow9
El Paso
Sale Terms:
  • US shipping only
  • First Class shipping unless otherwise noted
  • Paypal Purchase of Goods Option (no gift payments please)
  • I reserve the right to refuse sale at my discretion
  • No trades/No Proxy Buying
1) Malkoff MDC 18650 to E-Series Body [Sold/Shipped to The-David] $60
2) EagTac D25LC2vn SBT90 5700K De-Lens modified by Vinhnguyen54 $60 $65 $70
3) Thrunite T10vn II, SBT90 5700L De-Lens modified by Vinhnguyen54 $60 $65 $70
4) Convoy M2vn Oslon W2 modified by Vinhnguyen54 $50 $55 $60
5) Mateminco TK01vn NW XHP 50.2 modified by Vinhnguyen54 $55 $60 $65
6) Amutorch vg10vn SBT90 5700L De-Lens modified by Vinhnguyen54 $60 $65 $70
Body and adapter as shown. Switch is a McClicky. Adapter interfaces with an E-Series head.
Emitter: Luminus SBT-90. CW Tint with great output and throw for it's size. Uses DriverVN4 Programmable Driver/UI. You may want to re-adjust turbo/timer as I set it quite low since it gets very toasty fast. Includes box, high drain 18650 battery and accessories.
Emitter: Luminus SBT-90. CW Tint with great output for it's size. Uses DriverVNX2 Programmable Driver/UI. Includes box/tin, high drain 14500 battery and accessories.
Emitter: OSRAM OSLON White2 (6500K cool white). This was modified by Vinhnguyen54 @ CPF and direct from him. Strike bezel was heat treated and Vinh added his FS54 forward clicky switch. Uses the programmable VN4 firmware. You may want to re-adjust turbo/timer as I set it quite low since it gets very toasty fast. Includes a high drain 18650 battery, and grip ring. Nice clean and white beam with good throw. Approximately 1000 lumens.
Emitter: Cree XHP 50.2. Tank of a light with a nice 4000K tint and Stock UI (moonlight, low, medium, high, turbo). Includes an 18650 battery spacer, lanyard, protected 21700 Acebeam battery, and box. Full disclosure: The charging connector moved inward for some reason so a standard micro usb will no longer make contact. A 21700 battery can still be charged outside of the light in a charger.
moshow9
El Paso
Emitter: Luminus SBT-90. CW Tint with great output and throw for it's size. Uses DriverVN4 Programmable Driver/UI. You may want to re-adjust turbo/timer as I set it quite low since it gets very toasty fast. Includes 21700 battery.
aginthelaw
NJ, USA
i'll take the d25lc2vn. it's been a while...pm your paypal info and if you don't mind, reset the turbo timer to toasty
