Good to hear :twothumbs
OR-101
(1) onion ring - $21.00
(1 pk) warm white - $1.20
(1 pk) UV - $3.90
(2 pk) LEDs modded/trimmed - $2.00
Regular airmail - $3.50
TOTAL: $31.60
Thanks!
Robert
No worries at all, thanks for letting me know.
The LEDs are seated very nicely with mine, no movement.
I use a trimpot adjustment tool that I have to adjust it, which is similar to a tiny screwdriver (I was glad to be able to use it again). An eyeglass screwdriver will work well, too.
Enjoy!
Vincent, thanks. I know nothing about adjusting trimpots, hence my question before I started to fiddle with it. I read back through the "construction" thread ... I have the warm white and white LEDs, so I think I am just going to leave the trimpot in the default (medium) position and go from there.I assume if you have a screwdriver small enough to remove the original rings, you should have a screwdriver that will do the trimpot. Anyway the trimpot is not meant to be 'played' with it has a limited cycle life so don't tune it like the radio knob.
With the new version, you shouldn't have to worry about little trimpots, everything will be digital. I dont know when I can get to start building it, there's a little bit more stability I have to tweak about, it detects low and high of the tailcap switch.
