Sold/Expired FS: Solarforce L2P WARM XPG programmable
Zefiryn
KRK PL
Hi Guys
For sale modded Solarforce L2P HA III:
- selected low fV XPG emitter
- bin XPGWHT-L1-0000-00CE7, tint tint 7B4 3100K
- OP reflector
- double coated glass
- Programmable driver
Driver functions:
* 3 mode Driver -modes can be changed by 1 or 2 clicks (configurable)
* Memory mode can be turn on/off
* Brightness settings: adjustment from 0.4 to 100%
- super-low mode (0.4% brightness )
- digital control of Fast-PWM)
- brightness settings on/off (configurable)
* No Flickering effect
* Automatic voltage control ( configurable):
- low battery voltage Warning (<3.05 V)
- moon-mode: power saving mode with reduced brightness (<2.9 V)
- discharge protection (<2.8 V)
* optional configurable strobe mode, can be switched on/off
If turned on, strobe mode available as a 4th mode
Control :
* Mode change: 1 or 2 clicks (configurable)
* Brightness : 3 clicks - enters mode brightness settings (ramping from 0.4-100%) single click memorise desired level
* Driver configuration : 5 clicks - enters driver configuration mode:
1-click at high or low light selecting Yes/on (high), no/off (low)
+ Strobe mode on/off
+ 1 or 2 clicks mode change (yes/no)
+ Voltage control on/off
+ Memory on/off
+ Brightness settings on/off (if off then brightness regulation disabled)
canceling changes and exiting configuration mode automatically after 6 full cycles with no change
$ 59 shipped
Hi guys,
I've just made some more nice mods using aurora V6 hosts.
same driver , +cool white XPG emitter, will provide some photos and specs later today.
I will not sell drivers separetly as I have very limited quantity at the moment.
I'm using 3x7135 AMC 1000mA linear driver with newest DF/AMC-2.2 firmware made here in Poland.
DO you have some instructions for how to program the driver modes, so we can familiarize ourselves prior to your next sale?
Its very easy ;)
to change brightness:
1.switch flashlight on, change to mode you would like to program.
2. triple click enters mode brightness settings, flashlight will signalize it by two double blinks, than brightness will start ramping up an down from 0.4 to 100% in 9 steps, when it reaches 100% it will be signalized by single blink. Single click memorizes desired level and ends programing procedure.
3. repeat 1. and 2. to change rest of the modes.
to change driver configuration:
2. do 5 clicks to enters driver configuration mode
In configuration mode you will see two light levels: high and low changed every second five times. each high/low represents one function respectively :
1. Strobe mode on/off
2. 1 or 2 clicks mode change (high 1/low 2)
3. Voltage control on/off
4. Memory on/off
5. Brightness settings on/off (if off then brightness regulation disabled)
clicking on high means YES/ON, on low level means NO/OFF
for instance I would like to disable memory function:
5 clicks enters configuration mode
1. click on high light level
2. click on high level
3. click on high level
4. click on LOW level
5. click on high level
flashlight ends conf mode and goes back to mode than has been used recently. if you dont make any changes after 5 high/low blinks it will also end conf mode .
hope it is clear now ;)
Aurora'a available here :
http://www.candlepowerforums.com/vb/showthread.php?p=3392937#post3392937
